What did you to or with your RX-7 Today?
Old May 26, 2010 | 04:10 PM
cody205's Avatar
I saw this in a thread elsewhere on this forum, and thought WE should have one too!
What did you do to or with your RX-7 today?
Old May 26, 2010 | 04:21 PM
al0389's Avatar
Lima!!!
I took pics for my part out thread...
This weekend I swapped drievetrains on my vert and gxl, but the motor is left to do this weekend. Also, swapped brakes and suspension, since I have coils
The vert had TII drivetrain...
Old May 26, 2010 | 04:34 PM
rxtasy3's Avatar
get in it and drive.
Old May 26, 2010 | 04:47 PM
ray green's Avatar
Gone
I just finished changing the oil. Why do RX-7's run so much better after you change the oil?
Old May 26, 2010 | 04:56 PM
blackdeath647's Avatar
weak minds wear the crown
i don't think it's because they NEED the oil is it?
Old May 26, 2010 | 05:54 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
i just discovered one of my exhaust manifold studs is broken off in the housing, good times..
Old May 26, 2010 | 05:56 PM
waldog's Avatar
Whipping thru traffic.
Nothing. It's sitting waiting for me to swap the transmission (will happen saturday).
Old May 26, 2010 | 06:25 PM
cody205's Avatar
is your avatar of a rotor cut in half?
Old May 27, 2010 | 07:28 AM
NoviceRotaryTech.'s Avatar
Home-brew Rotary
Nothing yet.
But yesterday I tightened up the alt belts, they keep coming loose.
I also found that's its possible to snap the adjusting bolt if tightened too much.
Old May 27, 2010 | 07:32 AM
waldog's Avatar
Originally Posted by NoviceRotaryTech.
Nothing yet.
Been there and done that.
$18 at mazda dealer for a original one or $1 at ace hardware for a non original that works just as good.
Old May 27, 2010 | 08:53 AM
evot23's Avatar
Classy
Put the car cover on after charging the battery
Old May 27, 2010 | 03:41 PM
Acesanugal's Avatar
Winter Rotary
Went to the bank. I wish the car had A/C installed...
Old May 27, 2010 | 03:42 PM
Acesanugal's Avatar
Winter Rotary
Ray, to answer your question, all cars run/idle/sound a little better after an oil change. Oil breaks down and loses it's ability to effectively coat and lubricate things inside your engine. Ya big silly!
Old May 27, 2010 | 05:06 PM
20B10AE's Avatar
Gone Darkside
Took pictures of the vert interior for the 4 pt bar fabricator. Ran a longer wire for the momentary switch on the carputer. Added red LED map lighting.
Old May 27, 2010 | 05:17 PM
papsmagu's Avatar
nothing sat in the garage because i broke it at the track last friday
Old May 27, 2010 | 05:20 PM
fc3spro26's Avatar
turbo FB FTW!!!
Changed the plugs on my T2 , put the old ones in my turbo Fb to break in the fresh motor ...
Old May 27, 2010 | 06:01 PM
iheartthewankel's Avatar
Lettuce be cereal
I drove to the store to buy clothes and then drove back home
Old May 27, 2010 | 06:55 PM
that's what it looks like.
btw, my girlfriend left the lights on all day and screwed up my battery, so i got a new one, i'm glad it was still under warranty, but my buddy still charged me $5 dollars for gas .
Old May 27, 2010 | 07:31 PM
ray green's Avatar
Gone
After I changed the oil, I made a video, with Memorial Day themes:
http://www.youtube.com/watch?v=Az3xTc3jKBA
Old May 27, 2010 | 08:20 PM
jm93rx7's Avatar
Committee Member #3
Went to the body shop to see progress and saw none
Old May 27, 2010 | 09:37 PM
NoPis10's Avatar
Committee Member #2
Pulled it out the garage to wash it BUT the rain came down 1st..
Will try again tomorrow so I can throw the "FOR SALE" sign on her... Bitch upset me....
Old May 27, 2010 | 10:27 PM
jm93rx7's Avatar
Committee Member #3
Originally Posted by lwnslw
Will try again tomorrow so I can throw the "FOR SALE" sign on her.......
The committee has spoken.....
Old May 28, 2010 | 12:35 PM
papsmagu's Avatar
that is correct. the for sale being posted on the car was turned down prior to the committee meeting and did not even make the agenda. the decision is final
Old May 28, 2010 | 12:42 PM
Home-brew Rotary
Instead Give it away!!!!!
Old May 28, 2010 | 12:46 PM
CUBA6942's Avatar
Joe the club will not let you sell the car.... what happened...???
