Hydraulic E-Brake?
Old May 20, 2010 | 02:53 PM
ashleyanne's Avatar
Hydraulic E-Brake?
I've read up on hydraulic e-brakes and it seems as though they're not as efficient as stock e-brakes if your car is just a DD. I was just curious if anyone is running a hydraulic e-brake, and any thoughts about them.
Old May 21, 2010 | 10:08 AM
Sarusanj's Avatar
QM
Veteran: Navy
Veteran: Reserves
There's pretty much no reason to have them on a DD. I've only seen it once, and the guy did it because he had a rear BBK that couldn't use the stock ebrake. Never saw how it was actually set up though.
Old May 21, 2010 | 11:59 AM
Battle Cat's Avatar
Space cadet
Pm danegerous on the forum he has one on his drift fc
Old May 21, 2010 | 12:09 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
any replacement for the stock E brake interests me. i could then run an uprated rear rotor and perhaps 4 piston r caliper.
what links do you have?
howard
Old May 21, 2010 | 02:11 PM
Sgtblue's Avatar
Urban Combat Vet
Maybe you could run some version of a MICRO-LOCK system? That would operate all four corners through the existing lines. They use them on larger trucks and off-road vehicles, but I think they're a little pricey. I'm also not certain of the effects of long term use/engagement.
Old May 21, 2010 | 03:36 PM
jkstill's Avatar
Searching for 10th's
You may be referring to Mico, not Micro.
Here's a product sheet: http://mico.com/products/images/37_docfile.pdf
Here's a site that has some for sale, though I don't know if any of these are appropriate for an FD http://www.awdirect.com/default2.asp...TN&CID=AWGLVTN
Old May 21, 2010 | 06:33 PM
the Mico Lever Lock, looks like it would solve the e brake problem... for $213. we can now run a real rotor and caliper on the FD.
hc
Old May 22, 2010 | 05:42 AM
Sgtblue's Avatar
Urban Combat Vet
Yes, I was. Sorry, and thanks for clarifying it.
Old May 22, 2010 | 06:35 AM
R-R-Rx7's Avatar
Rotor or no motor
hc
Mico also makes the same pump without the lever. its cable activated so you can still use the oem handbrake (interior). As for the 4channel ABS (96+) Mico also makes a dual channel cable activated pump
Old May 22, 2010 | 07:10 AM
R-R-Rx7's Avatar
Rotor or no motor
i just realised you had the link there. both cablelock and dual locks are there
Old May 22, 2010 | 07:16 AM
Gurew's Avatar
meh looks too bulky heh
Old May 22, 2010 | 07:21 AM
R-R-Rx7's Avatar
Rotor or no motor
its actually tiny. i have the dual channel one
Old May 22, 2010 | 07:23 AM
Gurew's Avatar
pics that show size??
LongDuck
Oct 7, 2015 08:12 PM
