Oil is a must right??!
Old Apr 22, 2010 | 03:40 PM
dat_kid's Avatar
How often should i fill my car with oil? Its an 87' fc n/a. Help?
Old Apr 22, 2010 | 04:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Oil consumption varies with how hard you drive the car and the condition of the oil control rings. Also if you have any leaks, the oil level will drop faster. Check the dipstick and add it as necessary. I average about a quart every 3000 miles.
Old Apr 22, 2010 | 04:38 PM
rxtasy3's Avatar
if ur one of those that never ever checks things like the oil level then a rotary isn't for u.
Old Apr 22, 2010 | 04:52 PM
funkjaw's Avatar
Instead of checking all the time I just wait until the low oil buzzer/light comes on when I take turns fast. I have to add a quart about every 3 weeks.
Old Apr 23, 2010 | 12:57 AM
dat_kid's Avatar
thanks for the info. lots of help
Old Apr 24, 2010 | 10:45 AM
Aaron Cake's Avatar
Engine, Not Motor
Not really great advice...At that point the oil pump is already sucking air.
Old Apr 24, 2010 | 01:38 PM
bhop's Avatar
Semi P-PORT
It does vary depending on how hard you drive. Try coming up with a plan. For me I change my oil every 1,000-2,000 miles but I have a na 3 rotor and I'm sort of weird when it comes to maintaining proper performance for my RX-8. However do not wait for the oil light to come on simply because it is not a good habbit. Practice changing your oil every 2500 miles.
Old Apr 25, 2010 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
There is absolutely no reason to change the oil ever 1K to 2K. That is just a big waste of money, time and resources. I can't imagine changing the oil every 1K. I'd be doing it every 2 weeks. Every 2.5K is still a bit much.
To each his own, but remember this is the highly impressionable new users forum, so advice should be given that is valid for most people. Following the manufacturers recommended oil change interval is good advice.
Everyone should be popping the hood and glancing at the engine everytime the car is filled with fuel anyway just to make sure that everything is OK. Every two fillups, check the oil...
Old Apr 25, 2010 | 11:57 AM
dat_kid's Avatar
Yea my friend warned me about the light coming on, i was trying to see if there was an "accurate" time to add oil
Old Apr 25, 2010 | 01:43 PM
7beast's Avatar
i 2nd that
Old Apr 25, 2010 | 03:20 PM
Cordt's Avatar
just check it every time you fill up with gas, or every week. whichever comes first.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
