Electrical Alternator Question
Old Apr 22, 2010 | 01:57 AM
DoritoSA22's Avatar
Haven't started my car in more than a week...found out battery is dead and jumped it to start. Drove around for about 15 minutes and the next day i went to start the car the battery died again. Jumped it again and it started no problem then i noticed wen i turn on headlights or blinker my stereo turns off then back out again...seems like the car is losing electrical power, could this be the alternator? Or just the faulty battery? The alternator warning light doesn't stay on though, wouldn't this have stayed on if it was an alternator problem?
Old Apr 22, 2010 | 04:40 AM
Oneiros's Avatar
if the battery is dead you need to run the car for more than 15 mins to charge it up or it wont start again, take it for a good long run.
easiest way to test the alternator is get a multimeter and measure the voltage across the battery terminals when the car is running. it should be a bit over 14V.
Old Apr 22, 2010 | 10:37 AM
rxtasy3's Avatar
check the terminals at the battery. poor connection from corrosion build up or loose terminals will cause these problems.
Old Apr 22, 2010 | 11:52 AM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
Easy way to check for alternator is take off the + battery cable while car is
running. If it still runs then it is good.
Sounds like you're grounding something out that is draining the battery.
rotor_veux
Sep 3, 2015 07:10 PM
rotor_veux
Aug 31, 2015 07:49 PM
