Switched Power
Old Apr 19, 2010 | 07:18 PM
82FanTC's Avatar
Work in Progress
Switched Power
I am looking for the easiest way to hook power up to only turn on with the ignition on. I recently hooked up a wideband controller and ran the power from a second gen fuse box I swapped in where the fuseable links used to be. I was under the impression this was switched but to no avail it is not.
How can I hook it up so it only comes on with the ignition on without completely re-running wires? Or if I have to re-run wires where do I hook it into? I am completely ignorant when it comes to finding ignition on only power.
Thanks
Old Apr 19, 2010 | 08:38 PM
Sgt Fox's Avatar
Stigulus Moderatorai
You could use the power to the cig lighter to toggle a relay for your switched power, thus keeping your existing fused wire and not placing load on any existing circuit.
Old Apr 20, 2010 | 06:24 AM
82FanTC's Avatar
Work in Progress
anywhere to get it from under the hood? How about from the wiring harness? When I took out the rats nest I clipped all the unused wires but left just enough at the harness to be able to splice a wire back on.
Old Apr 20, 2010 | 07:24 AM
t_g_farrell's Avatar
Waffles - hmmm good
Get it off the positive of the ignition coil. Thats always a switched 12v source. I use it to trigger my relays for the electric fans.
Old Apr 20, 2010 | 08:02 AM
rxtasy3's Avatar
since i don't even use mine and it probably don't work anyway, and i could be wrong concerning these cars but all cig lighters have +12v all the time. and i agree with tim, just get it from the + side of one of the coils.
Old Apr 20, 2010 | 08:14 AM
82FanTC's Avatar
Work in Progress
Perfect. I love it when there is such an easy answer!
Thanks guys.
Old Apr 20, 2010 | 10:00 AM
74RX4's Avatar
Round and Round
Sarg is correct, of course. The lighter is switched. As already mentioned, the Black/white stripe wire connected to the positive terminal on each coil is the easiest connection point under the hood.
Old Apr 20, 2010 | 12:30 PM
Sgt Fox's Avatar
Thanks 74RX4. Most Japanese cars have the lighter socket as switched 12VDC whereas US made cars use constant 12VDC.
Queppa
Nov 18, 2024 03:47 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
