Turbo questions
Old Jun 20, 2002 | 08:38 AM
AbecX's Avatar
Thumbs up Turbo questions
Should be able to do it cheap, maybe $1,000 tops. Is their something I am over looking here? Computer, fuel, engine build? '86 n/a rx7 is the car.
Fill in the blanks here otherwise I might get started.
J/Y Turbo = $50
J/Y Intercooler = $50
Rebuild Turbo = $100
Custom Tubing = $300
Bigger injectors = $$$
Bigger pump = $$$
Gauges = $150
Misc. = $100
~$1,000
Thanks for any insight.
Old Jun 20, 2002 | 11:02 AM
SaabGuy's Avatar
Bigger pump will cost you about 125
larger injectors... maybe 150-300 depending on what and how many i guess.
then you need some way to control them, Arron Cake is doin alright so far with his SAFC - thats 300-350
Hope you know hot to weld.
I think you need the entire tII intake man as well.
Hey did I mention theres an 87 tII in the bargain news for $1200 bux??? Says fair condition and runs;
www.bargainnews.com
Old Jun 20, 2002 | 11:05 AM
Ryde _Or_Die's Avatar
www.bargainnews.com
Seems like a better idea. Buy it, sell the NA and fix the TII up.
Old Jun 20, 2002 | 11:41 AM
AbecX's Avatar
I bought this n/a for $250. Spending $1000 to me isnt very much and it will put out more power then a stock TII. Thanks for the info so far.
Old Jun 20, 2002 | 11:47 AM
Why will it be putting out more power than a stock TII? What turbo are you putting on it? Only difference will be that you will have higher compression which means it can't handle as much boost. Plus the tranny can't handle as much power either. I'm gunna stick with my "sell the NA and buy a TII" advice but good luck in your project either way.
Old Jun 20, 2002 | 11:52 AM
AbecX's Avatar
How much can the tranny handle. I dont plan on doing 6000rpm neutral drops w/ slicks on the back, more the top end racing.
Old Jun 20, 2002 | 11:53 AM
Felix Wankel's Avatar
Super Newbie
You forgot the manifold and the spacer, the downpipe, the bypass valve...
Old Jun 20, 2002 | 11:54 AM
RETed's Avatar
... neutral drops...
It's an automatic???
-Ted
Old Jun 20, 2002 | 11:57 AM
AbecX's Avatar
No, its a manual, pardon my gross use of words
banzaitoyota's Avatar
What Subscription?
I'll refrain from a smart-*** comment at this point in time.
AbecX's Avatar
The piping isnt that big a deal. Bypass valves are like $30.
Old Jun 20, 2002 | 12:00 PM
AbecX's Avatar
Whats the deal on the T2 intake, why cant you just run the stock n/a one?
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
