Top of my hit list
Old Apr 14, 2010 | 05:13 PM
Bob Holton's Avatar
recycled teenager
Top of my hit list
The knot head engineer that located the temp sensor on a 12A, and the suceeding knotheads that put theoil filter and plumbing right in front of it, you get to turn 1 flat at a time. GRRRRRR
Old Apr 14, 2010 | 07:47 PM
ray green's Avatar
Gone
Not GRRRRRR Bob, you need to go OMMMMMMMM........ It's the Zen of 12A's. Did you degrease the area first? That will lower the frustration level ten fold.
Old Apr 15, 2010 | 06:56 AM
Bob Holton's Avatar
recycled teenager
Ray; Hello again. Yes ,I even washed the whole engine bay at the car wash, It is that my hands and fingers dont work like they used to,but it is still a dumb engineers fault. I am still nibbeling away on the RX 3 and the seven. Next biggie will be to find the leak on the omp. and then the turn indicator return . If you have any gratituous tips or tricks, I am waiting to accept any or all. The cars are getting older,but darn it so am I. Thank you . Bob
Old Apr 15, 2010 | 10:50 PM
EvilJester's Avatar
Apply clever comment here
a 1/4 inch rachet, a 4 inch extention and a deep socket is all it took to get my temp senser out was super easy, took like 8 seconds. or am i not thinking of the same thing?
located right below the oil filter on 12A right?
Old Apr 16, 2010 | 04:55 AM
mazdaverx713b's Avatar
Have RX-7, will restore
i use a 3/8" drive with a 3" extention and a 12mm deep well socket when the oil pressure sender is removed..though a 1/4" ratchet with extension fits better and helps to snake past the oil pressure sender when its in place
DerpyToast
14
Nov 23, 2024 05:19 PM
Donald Hampton
16
Nov 23, 2022 06:38 PM
rotor_veux
Sep 3, 2015 07:10 PM
