Possible 12A going bad?
Old Apr 11, 2010 | 08:59 PM
Verneuil's Avatar
I was messing around with my alternator making sure the belt was tight and i was rotating the alternator by hand when i noticed that the engine was rotating also. Car was in nuetral. There was almost no effort in rotating the engine. Now the car has pretty good power and starts runs idles all fin whats up with that? Also saw a post for a S5 Turbo II engine for cheap that runs. Would it be better to swap that into my car?
Old Apr 11, 2010 | 09:27 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
That is ok, you can normally turn the engine over by hand.
Old Apr 11, 2010 | 09:58 PM
Verneuil's Avatar
Ok sweet. Just got a reply on the turbo II engine. Not just one but two. Ones blown the other runs. Looked at some posts to do the swap just wondering if would be fessible to do in a short amount of time. Its my DD, And its a sweep deal for two turbo II engines.
Old Apr 11, 2010 | 10:45 PM
AcidAngel7477's Avatar
We're All Fkd..
if your going to do the s5 t2 swap there's alot of modification that you would have to do. such as the oil pan the front cover and the power to the ecu...search about that topic before you go through with it.
:AA:
Old Apr 11, 2010 | 10:52 PM
rxtasy3's Avatar
any engine swap outside of one like was in it originally is not going to be just a simple remove, install and then go drive. and depending on ur knowledge and ability, a t2 swap and take months to complete. and as for that ability to turn the engine by hand, yes u can. rotary engine doesn't really build compression til it's spun with the starter.
Old Apr 12, 2010 | 05:18 AM
Verneuil's Avatar
Alright that clears things up really well. I thought i was in the OMG im screwed bubble. The S5 engine swap, If i were to get everything before hand and get things prepped to could it be done quickly? I know id need the diff cover and the oil pan, pick up and somehow get a hold of a wiring harness and strip it down and what not. I am pretty knowledgeable, Feed me info and see what happens lolz. Would it be possible to use the turbo II parts modify them to fit the 12A and be done?
Old Apr 12, 2010 | 05:37 AM
Oneiros's Avatar
running a nikki blow through turbo would be a lot easier to install, no removal of the motor necessary.. your current motor is fine by the sound of it, if you really want to make sure then compression test it
Old Apr 12, 2010 | 07:24 AM
Verneuil's Avatar
I thought that too. But idk what I need to do boost prep the nikki. The tubo II would be all done and I would just need to fit it in my car
Old Apr 12, 2010 | 10:17 AM
Kentetsu's Avatar
Your motor could be a little down on compression, probably due to carbon buildup. I run a can of Seafoam through the tank every couple of months to keep the carbon in check, and it does a great job.
Don't try to get fancy and dump it down the carb, or feed it in through a vacuum line though. That just makes a huge cloud and wastes the product you paid good money for. Just dump it in the tank and drive.
Old Apr 12, 2010 | 12:32 PM
Verneuil's Avatar
hmm i did run seafoam the other week. But i put it in on a low tank and forgot to fill it up. So i ran in with only a couple of gallons of gas. Ill do it againe though.
Old Apr 12, 2010 | 12:33 PM
Verneuil's Avatar
i was just looking around, If i did the turbo II swap i could run a MegaSquirt ecu with the mods they have listed and that would work great also.
Old Apr 12, 2010 | 12:34 PM
Verneuil's Avatar
Here http://www.diyautotune.com/tech_arti...zda_fc_rx7.htm
The1Sun
Sep 18, 2015 07:13 PM
vy_MR2
Sep 16, 2015 06:39 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
