Power FC My Timing maps-trying for 23 psi
Old Mar 25, 2010 | 05:28 PM
catch-22's Avatar
Hey guys im slowly working my way to 23 psi and currently im at 20 psi. First my cars backround- holset WH1E, 550/1600, supra pump, 50/50 water meth, 4in exhaust, streetport. Wanted you guys to take a look at my timing maps cause it feels like the car is getting held back. I was initially tuned for 15 pounds so i know it was fine at that pressure. Also what value are you running so the map will read to 23 pounds. thanks!
sorry i cant screen print im on a mac with windows
Leading
8 12 12 12 31 32 32 33 35 38 38 38 38 38 38 38 38 38 38 38
17 17 17 17 30 31 32 33 34 37 38 38 38 38 38 38 38 38 38 38
17 17 17 17 28 29 30 32 33 36 38 38 38 38 38 38 38 38 38 38
26 26 26 26 26 27 30 30 32 34 37 38 38 38 38 38 38 38 38 38
26 26 26 26 21 22 26 26 27 28 30 33 36 38 38 38 38 38 38 38
12 12 12 18 20 20 24 24 24 25 28 29 35 38 38 38 38 38 38 38
9 9 8 13 18 18 22 23 23 24 25 28 33 35 38 38 38 38 38 38
9 9 9 16 17 19 21 22 22 23 24 27 32 32 36 37 38 38 38 38
9 9 7 12 16 18 19 20 20 21 22 26 29 31 32 33 33 34 38 38
9 9 5 11 13 15 16 19 20 21 23 25 27 28 29 29 29 30 35 35
1 9 5 8 10 12 13 16 18 20 21 22 24 25 25 25 26 26 29 29
1 2 3 3 7 7 9 13 14 16 17 17 17 17 17 18 20 22 25 26
1 2 2 3 5 6 6 7 9 10 10 10 10 10 10 11 15 18 20 22
1 2 2 3 5 5 5 5 7 7 7 7 7 7 9 10 14 17 19 21
1 2 2 2 4 4 3 5 6 6 6 6 7 7 9 10 13 16 18 20
1 2 2 2 3 3 4 5 6 6 6 6 6 6 8 9 12 15 17 19
1 2 2 2 3 3 4 5 6 6 6 6 6 6 8 9 10 14 16 18
1 1 1 1 1 1 2 3 5 5 5 5 5 5 7 7 6 6 6 6
Trailing
5 9 9 9 28 29 29 30 32 35 35 35 35 35 35 35 35 35 35 35
14 14 14 14 27 28 29 30 31 34 35 35 35 35 35 35 35 35 35 35
14 14 14 14 25 26 27 29 30 33 35 35 35 35 35 35 35 35 35 35
23 23 23 23 25 24 27 27 29 31 34 35 35 35 35 35 35 35 35 35
23 23 23 23 23 19 23 23 24 25 27 30 33 35 35 35 35 35 35 35
9 9 9 15 17 17 21 21 21 22 25 26 32 35 35 35 35 35 35 35
6 6 5 10 15 15 19 20 20 21 22 25 30 32 35 35 35 35 35 35
6 6 6 13 14 16 18 19 19 20 21 24 29 29 33 34 35 35 35 35
6 6 4 9 12 14 15 16 16 17 18 22 25 27 28 29 29 30 34 34
6 6 2 8 9 9 10 13 14 15 17 19 21 22 23 23 23 24 29 29
-2 6 2 5 6 6 5 8 10 12 13 14 16 17 17 17 18 18 21 21
-2 -1 0 0 3 1 1 3 4 6 7 7 7 7 7 8 10 12 15 16
-2 -1 -1 0 1 0 -2 -3 -3 -2 -2 -2 -2 -2 -2 -1 3 6 8 10
-2 -1 -1 0 1 -1 -3 -5 -5 -5 -5 -5 -5 -5 -3 -2 2 5 7 9
-2 -1 -1 -1 0 -2 -5 -5 -6 -6 -6 -6 -5 -5 -3 -2 1 4 6 8
-2 -1 -1 -1 -1 -3 -4 -5 -6 -6 -6 -6 -6 -6 -4 -3 0 3 5 7
-2 -1 -1 -1 -1 -3 -4 -5 -6 -6 -6 -6 -6 -6 -4 -3 -2 2 4 6
-2 -2 -2 -2 -3 -5 -6 -7 -10 -10 -10 -10 -10 -10 -8 -8 -9 -9 -9 -9
Old Mar 25, 2010 | 05:30 PM
catch-22's Avatar
Oh and my PIM values are
1000
2000
3000
4000
5000
6000
7000
8000
9000
10000
11000
12000
13000
14000
15000
16000
18000
20000
22000
24000
Old Mar 25, 2010 | 06:12 PM
arghx's Avatar
rotorhead
you need to rescale your maps. 24000 PIM is 1.4 kg/cm^2 boost.
1.4 kg/cm^2 * 14.22 psi per kg/cm^2 = ~20psi . So you've maxed out the map.
Old Mar 25, 2010 | 06:38 PM
catch-22's Avatar
Right thats why i havent gone above 20. Can i just change just the last PIM value so it reads higher or will i have to rescale the whole thing?
Old Mar 25, 2010 | 08:47 PM
fd_neal's Avatar
Hard to really comment when its not in a chart, and I cant comment on the trailing as I like to look at the split.
IMO the leading timing seems a bit retarded after the 14000 pim value. Granted 23psi is territory ive never ventured into I would think around 6* at peak tq on the leading. On your 15psi row I would run about 11* at peak tq and scale it evenly down to 6* for 23psi. PLEASE NOTE ive never intentionally ran more than 16psi.
To answer the question, when you rescale the PIM values it is entirely independant from the map. So when you change the PIM scale the timing and fuel maps will sit exactly how they are but have new pressure values assigned to them.
Old Mar 26, 2010 | 09:41 AM
cewrx7r1's Avatar
Eye In The Sky
No memtion of a 3 bar map sensor which would be needed as the stock on only goes to about 17.5 psi.
Old Mar 26, 2010 | 12:05 PM
arghx's Avatar
rotorhead
it depends so much on fuel quality and intake temps... i used to run 10 degrees at 21psi for 100 octane unleaded
Old Mar 26, 2010 | 12:26 PM
catch-22's Avatar
Yeah i have one forgot to mention that.
Old Mar 26, 2010 | 12:29 PM
catch-22's Avatar
ok cool, under boost i dont see over 30 degrees and often go into the teens. Knock never gets into the 20s as it sits now.
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
Microtech
Aug 23, 2015 11:04 AM
