Garrett turbo oil feed fittings
Old Mar 19, 2010 | 05:51 PM
TURSTY's Avatar
The wankel way!!
Its never the same is it :roll:
Ive had to replace the CHRA on my T51R after a motor failier and the new CHRA from Garrett is slightly different.
Turns out the oil feed on the old and new T51Rs are totaly different. The old one has this bolt on restrictor, and the new has the "bearing locating pin" according to the CRAP install instructions that came with it.
Im guessing this sort of oil feel needs to use a special flanged fitting that presses down on this "Pin"??
See pics to explain
Old core:
Bolt on fitting:
Inside of the fitting:
New core:
Old Mar 19, 2010 | 08:03 PM
Jason's Avatar
The one
Looks like you need this http://www.aptuning.net/Aluminum_Oil...tp-fla-008.htm
or this http://www.aptuning.net/Oil_Feed_Fla...tp-fla-020.htm
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
Kyo
Aug 14, 2015 02:00 PM
