Sponsored by: CARiD
Oil smells like gas!! HELP!!!!
Old Jun 18, 2002 | 02:26 PM
I have a 93 Auto FD and when I took it for an oil change recently it looked like the oil had turned into black water. It poured out and so I replaced it with a higher viscosity oil and hoped that it was just from running hard. Now I have been having a strange fuel problem that reminds me of a clogged fuel filter problem and it hesitates and burps on heavy throttle. When I checked everything out the other day it looked like one of the spark plugs had loosened and allowed some gunk to escape. I replaced them and checked the oil as I pieced everything back together. The oil was black again and this time had a slight smell of gasoline in it. WTF?
Old Jun 18, 2002 | 04:32 PM
peejay's Avatar
Old [Sch|F]ool
Some oil dilution is normal with a rotary especially one that runs excessively rich or misfires a lot. Loose spark plugs can cause misfiring (poor ground path/poor heat transfer) but it sounds like you may have other issues.
Old Jun 24, 2002 | 02:38 AM
yodaddy's Avatar
try having your timing checked. i had the same problem only much worse and it was my timing.
Old Jun 24, 2002 | 03:24 PM
Exclamation
What weight oil did you put in? Hopefully nothing heavier than 20w50...
Old Jun 26, 2002 | 02:33 PM
10W-30 Castrol GTX oil, I am curious about the timing, whats the best way to diagnose and repair the timing issues? Thanks guys for the responses.
-Chris
Old Jun 30, 2002 | 04:52 AM
i also have a similar problem in my Turbo II.... also very poor idle...around 500rpm.... i've tried to adjust the idle speed n fuel mixture.....no improvement.... i havent changed my fuel filter in about 15k mi.... hopefully that's the problem..
Old Jun 30, 2002 | 07:26 PM
diabolical1's Avatar
when was the last time you guys changed/cleaned you air filters? (just a thought ... sometimes we all overlook the simple stuff)
Old Jul 1, 2002 | 09:42 AM
I just put in a new air filter before the change in idle and boost problem. I'm just gonna change the oil 1 more time and see what happens. I did a small vacuum hose replacement and found a busted vac hose. I now have 10 lbs of boost from the 1st turbo but it drops to about 4 lbs of boost when the second one comes in, at about 4500 rpms. I checked the IC pipes and the Y-pipe connectors, they were all fine with no cracks. Last thing I can think of is a toasted or mostly toasted solenoid in the rats nest. Maybe the turbo pre-control? Thanks,
-Chris
Jutta_J
Mar 25, 2017 11:24 PM
R7rexy
19
Sep 2, 2015 10:24 AM
smikels
Aug 18, 2015 01:26 PM
