header options?
Old Jun 17, 2002 | 02:08 PM
cpt_gloval's Avatar
KARATE EXPLOSION
header options?
i spoke with my mechanic (steve hayes - same hayes, different shop). he mentioned that if i got a RB header, i'd have to change out the rest of the exhaust system since they intentionally made it so it doesn't bolt up to the stock system.
are there any other options? i have a RB midpipe that replaced my stock cats. all else is stock. i was wondering if there'd be an option where i can bolt the header up to the stock system...
Old Jun 17, 2002 | 04:01 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
A header that bolted to the stock system would be too short.
Old Jun 17, 2002 | 04:02 PM
adssoccer's Avatar
a rb header won't bolt directly to the main cat?
Old Jun 17, 2002 | 04:29 PM
not that I know of, but I never tried it - did it all at once... call them and ask maybe
Old Jun 18, 2002 | 06:04 AM
yayarx7's Avatar
Are you Nucking Futs?
mindtrain will bolt up to the stock cat.
Old Jun 18, 2002 | 04:50 PM
dule exi=oust
Question what would it take to put a duel exhaust on an 1987 GXL? A header and at least two per silencers with aux. port
tubes. What Muffler would be quite but not to restricting ?
Old Jun 18, 2002 | 04:57 PM
peejay's Avatar
Old [Sch|F]ool
The '79-80 RB header (as well as the Pacesetter) bolt up directly to the factory heat exchanger. I was happy to see that Too bad the heat exchanger is so restrictive.
Bruce, try the 2nd-gen forum.
Old Jun 18, 2002 | 05:03 PM
Pedestrian X's Avatar
SpAz!
well, is there anythign you can do abotu the heat exchanger?
Old Jun 18, 2002 | 05:25 PM
peejay's Avatar
Old [Sch|F]ool
RB sells a mini-presilencer that replaces it
What i did was buy a 2.5" Race Ready, cut it to the same length as the heat exchanger, made a couple flanges, and welded those in place. It wasn't any louder because I eliminated two major exhaust leaksa (the H.E. flanges were badly rusted and would not seal to gaskets) and the power improvement was noticeable on the street, VERY noticeable on the track
I could have done the same thing with just a regular pipe, but that's not as obnoxious
Old Jun 19, 2002 | 12:00 AM
I will, but it never hurts to get the opinion of other rotor heads, that is unless there heads are just to full or narrow. BTW I plan on putting Duel
exhaust on my first gen GSL-SE as well. PS did
(se)- Bruce just slip right past you. < GBG >
renjiv2
57
Jan 25, 2024 03:34 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
