Sponsored by: CARiD
FD Rebuild or Replacement
Old Jan 26, 2010 | 12:35 PM
LikeThunda's Avatar
Lol
which is recomended.? replacing an FD engine or rebuilding it...??
Old Jan 26, 2010 | 12:43 PM
linnadawg's Avatar
Pharmaceutical 7
whats wrong with it. You need compression numbers to help you decide.
Old Jan 26, 2010 | 01:21 PM
LikeThunda's Avatar
Lol
True, Not exactly sure, i was told that the Car needs a New engine....So i was thinking why not just rebuild...butt...they keep saying it just needs a New engine....Yea sorry for the lack of details..IM still waiting for my car to arrive.. =D
Old Jan 26, 2010 | 04:51 PM
linnadawg's Avatar
Pharmaceutical 7
Ask, the shop im assuming, why specifically you need a new engine. See if your compression is around 90-110 psi on all 3 points of each rotor. Was it overheating? Only take your car to known rotary shops. People like banzai racing and others do rebuilds for around 1300-1500$ as a base price. If you need rotor housings, lapped plates, or any internals replacement cost will go up significantly. Right now im spending around 4500$ because I needed new rotor housings and a new rotor.
Old Jan 26, 2010 | 04:52 PM
linnadawg's Avatar
Pharmaceutical 7
Rebuilding rotaries is one of the only ways to go really. You can get remans from mazda for ridiculous prices. If you wanted a motor built with all brand new internals your looking at like 7-8 grand.
Old Jan 26, 2010 | 07:03 PM
LikeThunda's Avatar
Lol
wow.. expensive...a basic rebuild just consists of new Apex Seals? what does a Legit Rebuild Consist of. id i do decide to rebuild the engine..?
Old Jan 26, 2010 | 09:53 PM
linnadawg's Avatar
Pharmaceutical 7
a basic rebuild consists of all internal o rings and seal replacement. If all of your hard parts are good the builder will reuse them and the cost stays down. If your apex seals are not broken or worn they wont be replaced unless you want a different seal. Check out this link. http://rotaryaviation.com/overhaul_kits.htm
Old Jan 26, 2010 | 11:23 PM
Lightbulb
This is incorrect.
As per Ray Crowe at Malloy Mazda, FD remans are not available, and have not been available for over a year.
He sells new (new) oem shortblocks for right around $4000. I know, I bought one
Old Jan 27, 2010 | 12:38 AM
SupaDoopa's Avatar
I just picked up a FD with a Mazda reman. I was told there was roughly 43K on the rebuild. I have a TT setup non-sequential. I was told roughly 60K was a good number to start looking for a rebuild to keep the costs and such down. True statement?
Old Jan 27, 2010 | 01:05 AM
linnadawg's Avatar
Pharmaceutical 7
Sorry never bought a reman before, was just reminiscing of a post with someone saying look what I found at mazda! It was over a year ago.
Old Jan 27, 2010 | 01:20 AM
linnadawg's Avatar
Pharmaceutical 7
I would say as long as you dont overheat, and keep an eye on your compression, there should be no need to spend money on a rebuild. Waiting for a broken apex seal though can be expensive.
Old Jan 27, 2010 | 12:03 PM
SupaDoopa's Avatar
So I hear.
Old Jan 27, 2010 | 02:13 PM
Banzai-Racing's Avatar
Rotary Specialists
Our $1500 base rebuild replaces every soft seal , every spring, apex seals, eleminates the thermal pellet, etc. Only things not replaced are the major engine components; rotors, housings, e-shaft, etc. These can be replaced if needed at additional cost.
http://banzai-racing.com/store/rotar...e_rebuild.html
Old Jan 27, 2010 | 02:38 PM
KKMpunkrock2011's Avatar
dorito powered
if your compression is good and you're not smoking like a ****, no need for a new motor/rebuild. I bought my current FD with a reman and has 15k on it, I wanna do a compression test while I've got it half apart for a new fuel system, but I gotta get a comp tester first.
Old Feb 4, 2010 | 02:50 PM
LikeThunda's Avatar
Lol
Thanks for all of the Help you guys,,, ill try and do a compression test...
what are good Numbers for a Rotary engine..??
and bad numbers which indicate rebuild time.?
Old Feb 4, 2010 | 04:50 PM
linnadawg's Avatar
Pharmaceutical 7
110+ psi good below 90psi is getting bad
Old Feb 6, 2010 | 09:39 PM
Syritis's Avatar
depending what is wrong with the motor and what needs to be replaced a rebuild motor could be 2-3grand plus the shops labor is extra.
Old Feb 27, 2010 | 08:13 PM
LikeThunda's Avatar
Lol
I did some Shopping around... i was told by many people that Lucky 7 Racing Does a very Good job. they are also about 20 Miles from mee soo its Very convenient.. =P
hoofhearted
NW RX-7 Forum
23
Feb 2, 2019 11:50 AM
rotor_veux
Sep 3, 2015 07:10 PM
sYnth.
Aug 19, 2015 06:27 PM
