rev problems
Old Jan 21, 2010 | 11:55 AM
matt_elliott's Avatar
rev problems
i have an 1986 rx7 and i cant go past 3500 rpms or it just cuts out like a rev limiter it jast started happening and i wanted to know what you guys thought this might be
Old Jan 21, 2010 | 12:00 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you haven't already done it, download a copy of the FSM through the links in the FAQ or here: http://www.rotaryheads.com/PDF/2nd_gen/index.html
Take a look at the Fuel and Emissions section and read up on testing the fuel injectors. Your problem sounds like the secondaries may not be firing. Are you able to rev the engine past 3500 RPM with the transmission out of gear, or does it only do it under load? The secondary injectors transition on at about 3800 RPM, but only do so under load conditions.
Old Jan 21, 2010 | 02:30 PM
LikeThunda's Avatar
Lol
easy fix.. Replace OMP! and get a Different ECU..... taking the ECU resets that whole LIMP MODE!! is what its called
and the OMP makes sure the oil is being fed to the engine..
i speak from Experience.. 2 Rx7 FC"S with bad OMPS... they both didnt go passed 3500 rpm//
check engine light would come on..etc....
Swapped OMP...and ECU..fixed..
NO problem
Good luck
Old Jan 21, 2010 | 02:48 PM
Top Down, Boost Up
^ An '86 RX-7 doesn't have limp mode, or a check engine light for that matter.
RedBaronII
Sep 20, 2015 11:29 AM
rotary_rx7fc
20
Sep 19, 2015 02:41 PM
The1Sun
Sep 18, 2015 07:13 PM
localized
Sep 16, 2015 12:18 AM
Adrian Anguiano
Sep 14, 2015 05:29 PM
