Ported wastegate to big
Old Dec 17, 2009 | 05:53 PM
MyLastEcstasy's Avatar
I ported the waste gate and it was to big for the cover, what types of problems would this cause?
Old Dec 17, 2009 | 06:09 PM
10yearrx7's Avatar
313 whp 247 wtq 8D
I have been told that you need to weld a washer on the flapper that will cover the hole
Old Dec 17, 2009 | 06:11 PM
Go48's Avatar
You will no doubt lose some or all of the boost if the wastegate remains partially open. You can try welding large washers to the "flapper" to cover the openings.
RotaryRocket88's Avatar
Top Down, Boost Up
It will hurt spool up time, so you'll be making boost later in the RPM range than normal. You should get a washer welded onto the stock door to cover the hole.
EDIT: great minds think alike?
Old Dec 17, 2009 | 06:12 PM
kk thanks guys
Old Dec 18, 2009 | 10:04 AM
Aaron Cake's Avatar
Engine, Not Motor
http://www.aaroncake.net/rx-7/s4wastegate.htm
Old Dec 18, 2009 | 04:29 PM
Originally Posted by Aaron Cake
niceee, thanks
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
Clacor
Sep 11, 2015 08:36 PM
chiefmg
Sep 10, 2015 07:46 AM
doritoloco
Sep 5, 2015 12:41 PM
