Disabling/Removing Turbo
Old Dec 7, 2009 | 07:31 AM
thejackal91's Avatar
Hey guys,
Is it possible to disable or remove the turbo from a third generation rx-7 and still have it working?
Thanks in advance.
Old Dec 7, 2009 | 12:44 PM
RotaryRocket88's Avatar
Top Down, Boost Up
For what reason? Engine break-in? On any turbos w/ internal wastegates you can remove the wastegate actuator and let the flapper doors move freely. It should be nearly impossible to make boost if the wastegate ports are large enough.
Old Dec 7, 2009 | 10:49 PM
danewbern's Avatar
Rogue Engineer
you should be able to do it. I saw one for sale a a dealership years ago where the turbo was blown, similar i would think to disabling the turbo. The car drove normally without boost, but it was pretty weak.
Old Dec 8, 2009 | 09:14 AM
Aaron Cake's Avatar
Engine, Not Motor
New driver? Restricted license?
It could be done, but will require a new exhaust to be fabricated, new intake arrangement, etc. It would be a lot of work and the result would be a very slow car.
Old Dec 17, 2009 | 07:55 PM
vipcivic's Avatar
there would be no point to that ,and would be a great power loss, its like having a acura integra with a gsr swap,taking it out and putting in a single cam non vtec from a civic, not worth it. if you want to save gas dont boost LOL
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
