radiator...
Old Nov 28, 2009 | 01:15 PM
evilpb11's Avatar
radiator...
ok..well my old radiator was leaking. I bought a new one and just put it on..with no fan..I let it run for a little while and it start getting a little. if i rev it up a couple times it will get to hot...is this because i dont have the fan on it or is it something else. also i do have a fan for it. it has to wire comming off it..one is the ground wire at least im pretty sure it is but i dont know where the other wire connects to...any help?
Old Nov 29, 2009 | 10:07 AM
Aaron Cake's Avatar
Engine, Not Motor
With no air circulating through the radiator, no cooling will take place.
What kind of fan? Aftermarket? More info is needed.
http://www.aaroncake.net/rx-7/efaninstall.htm
Old Nov 29, 2009 | 11:17 AM
rxtasy3's Avatar
yes there's no air flow thru the rad. and the other wire goes to +12v, but preferably thru a relay.
oyvindjs
Aug 30, 2013 08:33 AM
OK13B
Jun 4, 2012 05:26 PM
LittleAznBoy
Feb 8, 2012 12:07 AM
that one guy300
11
Sep 16, 2009 11:48 AM
