rebuild question
Old Nov 19, 2009 | 05:57 PM
n.taluckder's Avatar
MD rebuild question
hey everyone im currently in the process of rebuilding my s4 turbo 2 motor. currently the engine smokes after coming up to operating temp, with that said, it feels powerful and starts easily when cold or hot. so im just wondering is it the oil conrol seals that i must replace? Thanx in advance......
Old Nov 19, 2009 | 07:33 PM
ForsakenRX7's Avatar
zoom zoom go boom
Rotary aviation is another choice and their a bit better on the price.
Old Nov 19, 2009 | 08:10 PM
CrispyRX7's Avatar
Polishing Fiend
What color is the smoke? White and you have lost a coolant seal and are burning coolant. Grey and you are burning oil and have lost the oil control ring o-rings or you have a stuck side or corner seal. If you have a bad apex seal it wouldn't necessarily smoke but it would idle like crap and shake like a paint mixer in the engine bay. Rebuild kits from Atkins or Rotary aviation are a fair bargain.
FWIW,
Crispy
Old Nov 19, 2009 | 09:11 PM
K-Tune's Avatar
FD Daily
Originally Posted by XxGeTxRx7Xx
you could very well replace the apex seals, rotary performance sells dual spring 2mm apex racing seals for like 550 for all six seals which is all you need for a two rotor engine i bought them personally and they work fantastic, you can boost more and you will have a better over heating control, less overheating more to say
what does any of that have to do with smoking?
Old Nov 20, 2009 | 12:28 AM
therotaryrocket's Avatar
PIMP
Make sure you don't have bad turbo oil seals causing it to smoke.
Old Nov 21, 2009 | 07:03 PM
hey guys thanks alot for the info really appreciate it
Old Nov 21, 2009 | 10:45 PM
Mazda RX-7 EFINI TYPE's Avatar
If I recall correctly, a member recently had the same problem, and the turbo oil seals were the culprit...so you would probably want to check there first. And it's only coolant you're burning if the smoke smells sweet & burnt...unless of course you're running pure water...
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
SCinfidel
Sep 8, 2015 05:36 PM
rotor_veux
Sep 3, 2015 07:10 PM
