looking at a used 87 turbo 2
Old Nov 10, 2009 | 06:54 PM
kickinthedoor's Avatar
NJ looking at a used 87 turbo 2
so i was driving past my local used car lots and something cought my eye.... an 87 rx7 turbo 2. so i pull in a start conversing with the sales man and he tells me that the car has a problem with flooding out when you shut it down. so i take for a test drive with him sure enough it stalls out and wont start. (luckilly we were about 12 feet from the drive way). we push it back in the lot and continue talking, he wants $2700 and its got 126k . he also said it needed injector o-rings, which is the reason its flooding out. i called a local speedshop that works with rotary motors and the guy said ngk 4 prong plugs and new wires, cap rotor would take care of the problem. anyone think this worth grabing?
Old Nov 10, 2009 | 07:36 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Flooding (when warm) is a common problem that is usually fixed by having the injectors cleaned. There are local companies, or places like www.witchhunter.com that can do it by mail. Old injector o-rings can cause vacuum leaks that will cause poor idle, which could cause it to stall at a light, etc...
The local speedshop guy is an idiot. New plugs and wires won't stop flooding.
Old Nov 11, 2009 | 06:55 AM
NJ
thanks for the help. I really want to buy this car. In your opinion you think its worth picking up?
Old Nov 11, 2009 | 10:21 AM
Top Down, Boost Up
Probably. If it runs strong and doesn't seem to have any other major flaws, it could be a good pick up.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
