my redline suprise
my redline suprise
ok so im not sure if this is suppose to happen, but when i redline my 12a the horn goes off?
happen's every time, no matter what gear or what the situation is. once the needle hits 7 grand i get a loud BEEP!
this normal? like some sort of ghetto redline warning? or is something seriously effed up?
Yeah its not the horn, its a little buzzer. With some ingenuity, you can adjust when it goes off, disconnect it, or make it into a shift light instead of that annoying buzzer.
thanks guys
glad to know my cars not just trying to eff with my head
shift light you say? and i can adjust when the "buzzer" goes off? i must look into this. i just happen to have a few random shift lights from my old autometer tach laying around
glad to know my cars not just trying to eff with my headshift light you say? and i can adjust when the "buzzer" goes off? i must look into this. i just happen to have a few random shift lights from my old autometer tach laying around
Trending Topics
It's not an "upshift" buzzer; it's an "Over-Rev Warning." In it's stock form, it marks a theoretical line you cross on a stock engine at your eventual peril.
It came and went a couple times across the 1st gen timespan. 79's had them, 80's did not, later models some did.
here is a little write-up someone did on how to make it adjustable
http://www.jimrothe.com/mazda/overrev.html
And in LG? Not as many cat anymore. I think the coyotes ate em all...
I have both -- the stock overrev buzzer and a Raptor shift light. I like them both, but I give a slight nod to the shift light because of 2 things:
1) It's more accurate. The OEM tach reads about 10% too high. When the analog buzzer goes off, you're never quite sure what the RPM is. With a good digital shift light, it will go off at exactly the RPM you set it to.
2) It's easier to adjust the RPM limit on the shift light. On mine, I just turn a dial on the underside. With the buzzer, I'd have to open up the cluster . . .
On the SA's they were a literal buzzer mounted to the rear of the instrument panel, hooked into the tach circuitry.
Shainiac
Jul 17, 2019 02:20 PM
imitek
13
Oct 28, 2015 10:57 AM
rx8volks
Canadian Forum
Sep 1, 2015 10:46 PM
Its perfectly normal its an "Over Rev Buzzer" that was designed to remind you to shift.
