Sponsored by: CARiD
oil pressure ??!?
Old Oct 21, 2009 | 11:03 AM
csrRx7_86's Avatar
86 Projec7
oil pressure ??!?
what should oil pressure be at idle? i went on alldata and they gave me its 65-72 normal but didnt specify if at idle or 3000 rpm.
Old Oct 21, 2009 | 11:07 AM
csrRx7_86's Avatar
86 Projec7
1986 rx7 rtr2
Old Oct 21, 2009 | 07:41 PM
David0ff's Avatar
if u have ~60 psi at idle run away from yur car
idle ( ~1000 rpm) ... shouldbe ~ 10-30 psi depending on oil temperature and viscosity rating
Old Oct 21, 2009 | 07:57 PM
No_love_for_pistons's Avatar
Parts collector
I'm not at home now but u can check in the FSM. Download it and READ it. But like was said, at idle it should be below 30
Old Oct 21, 2009 | 09:29 PM
csrRx7_86's Avatar
86 Projec7
OK thank you guys,
i do have under thirty psi of pressure at idle and increases with rpms! i just wasn't sure mainly because on my rx8 it doesn't have numerals on the oil pres. gauge :\ . Also alldata did not state whether its was idle or anything it just said 65-72 normal...i have not done a oil change since i have had the car but it has not been driven so im going to put what manufacture wants when it come around to do it... Thanks again for the help
Old Oct 21, 2009 | 09:30 PM
csrRx7_86's Avatar
86 Projec7
OK thank you guys,
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
