Non- seq is not working for me!!!!!!! My boost pattern is messed up now!!!
Old Jun 7, 2002 | 07:43 AM
Pressurized's Avatar
OKay,so i did the non-seq mod a little bit ago with Chris and Ryan's help, but the thing is I cannot hold or sometimes even get to full boost and I cannot figure out what is wrong!!!
I have a PFC and before i did the mod my pattern held 15psi to redline. Now it sometimes gets to 15psi(depending on gear) but usually it bounces between 12-13psi.
I checked the door to make sure it's wired open all the way.
I have played around with vacuum lines and have switched from pre-control to wastegate and so forth, but either one give me the same result. Also i noticed that when i leave the sequential PFC function ON, it spools up much quicker and i have better response.
Does anyone have an idea of where my problem is?
This sucks because i had a perfect boost pattern before i did this and now it's messed up again.
Any opinions are welcome.
Old Jun 7, 2002 | 08:15 AM
2 hott's Avatar
I did the non-seq about 2 weeks ago. How do you tell which connector goes to which contorler will it do damage if connect worng?
Old Jun 7, 2002 | 09:58 AM
Yeah, I've switched the connectors back and forth, changed vacuum lines around and back. Always the same. I'll talk to Chris about it i guess.
2hott, when standing in front of the car the wastegate is on the right and pre-control on the left. The wastegate connector should have a yellow or white dot on it.
Old Jun 7, 2002 | 11:14 AM
Yeah, I've got the wastegate duty set as high as it can go...it doesn't seem to affect it any...
Old Jun 7, 2002 | 12:49 PM
Toadman's Avatar
Nomad Mod
hmmm. I think I'll check the coat-hanger on the flapper door on mine and safety wire it instead. Mine goes strong up to 7psi and holds that to redline.
sherff
Feb 24, 2019 12:09 PM
smikels
Aug 18, 2015 01:26 PM
