Street Port - PICS - Meaning???
Old Aug 26, 2009 | 01:30 PM
vdubjim's Avatar
Lightbulb Street Port - PICS - Meaning???
I did a few searches and couldnt find any good infos.
SO what does it mean exactly, and some before and after pics??
Old Aug 26, 2009 | 03:00 PM
mar3's Avatar
Administrator
It's like porting the heads and changing the cam on a V8 but the rotary of course, doesn't actually have either of those things. You're removing metal from ports of the engine block (...and possibly, preferrably, of the intake manifold, as well...) to streetport it. This increases airflow but it ALSO acts like you're adding a big cam if you extend the tip of the port...you get more "duration", more time spent "with the intake and exhaust valves" open gulping in air. I don't have pics, so I'm leaving that to the graphics nuts I know are on our website who keep these kinds of pics always close on hand.
Mario III
Old Aug 26, 2009 | 03:12 PM
vdubjim's Avatar
That is what i gathered from the posts, but again. WHAT is it?
How much is too much, where, etc.....
Hec's 79 gs's Avatar
https://www.rx7club.com/general-rotary-tech-support-11/porting-825760/
Check this thread, It has a lot of good info and pictures to explain porting on a rotary.
Old Aug 26, 2009 | 04:05 PM
mar3's Avatar
Administrator
Thanks for the assist...the avalanche of porting info in that thread will answer any question he may have...
Old Aug 28, 2009 | 11:44 PM
fcs3l0ve's Avatar
No Pistons!
you can use a porting template so you dont **** up
Old Aug 29, 2009 | 09:09 AM
vdubjim's Avatar
ya that thread is way crazy.
porting template, ive seen some for like 60.00, doesnt someone have on i can just print out and draw on the case?
Old Aug 29, 2009 | 10:13 AM
Aaron Cake's Avatar
Engine, Not Motor
A porting template only gives you the port shape. Pay the $60 because the maker of the template has gone through a lot of trouble (and engines!) to get those port timings.
However 90% of port work does not involve the face of the port.
Old Aug 29, 2009 | 11:35 AM
fcs3l0ve's Avatar
No Pistons!
i am never porting my engine myself, ill leave it up to the guys with experience.
Snoopy FD
Dec 8, 2015 01:45 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
