best way to spend $400 on my turbo II?
Old Jun 5, 2002 | 04:32 PM
RiceRocket's Avatar
Livin loud like TIMMAAAYY
what would be the best way to spend $400 on my turbo II? could i actually do anything at all?
Old Jun 5, 2002 | 04:42 PM
UniqueTII's Avatar
Slow and old
Is it stock now? How about struts/shocks? Maybe some better brake pads and tires. You can't do much performance wise with that much...an intake and a used cat-back.
Old Jun 5, 2002 | 05:49 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
A cone filter, DIY TID, downpipe/midpipe will run about $400, and give a pretty significant performance boost. HOWEVER, first you should make sure everything is fixed and all maintenance done.
Old Jun 5, 2002 | 07:23 PM
FreedS4's Avatar
Assuming everything is fixed, I'd do a DIY FCD ($10) DIY Boost Controller ($15), Walbro fuel pump ($100), RB 2.5 inch Downpipe ($90), single muffler ($70), have a local muffler shop bend and weld the rest of the exhaust ($80), cone filter ($30), and if you have any money left maybe an e-fan. Thats basically waht I did, and I'm very happy with it.
Chris
Old Jun 5, 2002 | 08:11 PM
RiceRocket's Avatar
What is DIY?
how can i tell if i have an aftermarket downpipe (i am the second owner and i am not sure of all the mods done by the previous owner) is there an up pipe?
i have done everything else mentioned except the brakes. what sort of brake pads would be best?
Old Jun 6, 2002 | 08:55 AM
UniqueTII's Avatar
Slow and old
DIY= Do It Yourself.
The stock pre-cats and cats (which the DP and MP replace) look like big power robbing POS's, which is what they are. If you have an aftermarket DP, it will just be a straight pipe with the O2 sensor in it.
Axxis pads are good, and so are Hawk...just don't buy a racing pad or you may have trouble heating them up on the street.
FD7KiD
15
Feb 26, 2021 10:12 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
Wolf_
Aug 11, 2015 04:23 PM
