What turbo for 500/600rwhp ?
Hi Guys
I've a FD with stock twins and stock port engine for now but, i want more power and i wanted to do a single turbo conversion.
I've being trying to find a good turbo that could give me arround 500/600rwhp, not on stock ports but with a large street port.
My mods for now are 550cc/1680cc injectors, supra fuel pump, hks twinpower, blitz fmic, full exhaust, all those things, my last dyno did 370rwhp at 16psi.
What turbo should i buy to get my goals ? and any extra parts...
I wanted a decent spool turbo on low rpm but with great power on high rpm
Have been looking to the borg warner s366xl ... what you guys think ?
Thanks
(sorry for my bad english guys)
Thanks
i had an interesting dyno session w an R85 which is a Borg Warner S362 w a larger hotside. looking at the compressor map for a TEC 300, S362, R85 i see max flow of 64 pounds per minute.
64 X 14.471 = 926 CFM/ 1.92 = 482 SAE max rotary rw hp.
my dyno runs produced 501 standard at 20 psi w pump gas and 1260 CC/Min of meth. at 20 psi the turbo makes 60 pounds max according to the compressor map. that's 462 standard.
i was very impressed w the R85... 414 foot pounds of (standard) Tq!
howard coleman
howard coleman
i had an interesting dyno session w an R85 which is i believe an S366 w a larger hotside. looking at the compressor map for a TEC 300, S366, R85 i see max flow of 64 pounds per minute.
also weird is Tim's Turbos ad for the S366. it states the turbo makes 80 pounds and has "one of the best looking compressor maps..." and the map (above) shows 64 pounds.
so what's the deal w these turbos and can you get the S366 w a large turbine and hotside?
howard coleman
howard coleman
Trending Topics
Are you looking for 500/600 hp at the wheels or crank? 500 hp is more doable, once you get into 600 hp your pushing more physical limits of everything.
Sounds like the bw 366 would be a good choice. Along with some form of aux injection, since you told me race fuel and e85 are not available to you. You will need to turn your base fuel pressure up also if you plan to keep the 550/1680 setup. Supra pump will most likely need upgraded too. You could run 2 stock FD pumps, which is what I'm doing. Or run 2 supra pumps since you already have one, or you can upgrade to a single large fuel pump, which would cost the most, but be the simplest. Rewire your fuel pump in any case. Look into a 4" exhaust system, and get a good tuner and some fat, sticky tires.
You will need a 3 bar or higher map sensor also. If you drag race from a dig you'll need some kind of clutch style differential, such as one from a turbo 2 or a kaaz. Solid differential and motor mounts and a tranny brace. Chromoly axels, then just start upgrading as things break.
That's almost exactly what I had to do. However, I still do not use a tranny brace but my PPF is welded up.
