Car trouble
Old Aug 7, 2009 | 07:27 AM
Paul wayne Parker's Avatar
IN Car trouble
I have a 1989 Mazda RX-7 convertible, it chokes out
when I drive it on the road, the engine light comes on and
then it runs awful
Old Aug 7, 2009 | 08:56 AM
Aaron Cake's Avatar
Engine, Not Motor
Pull the trouble codes. I'm betting the metering oil pump has failed and the car has defaulted to limp mode.
Old Aug 8, 2009 | 12:25 AM
IN car trouble
ok thanks! but also it does not do it on jack stands, only on the road,
I will get an obd 1 scanner and read the code. Thanks again
Old Aug 8, 2009 | 12:28 AM
ok thanks, but it only does it on the road not on jack stands.
I will get an obd one scanner and read it thanks again!!
Old Aug 8, 2009 | 11:06 PM
IN
can I just run 2 cycle in the gas and unplug it to see if that works, or will the ecm still shut me down.
Old Aug 9, 2009 | 07:16 AM
misterstyx69's Avatar
Retired Moderator, RIP
since It is an S5,NO..you cannot Disconnect the Oil Metering Pump.
It NEEDS to be connected and the ECU needs to SEE it Connected,(EVEN IF you decide to Premix.If you decide to Premix you have to Take the OMP out and Dangle it Somewhere in the engine bay..That or Go Standalone Computer.)
you need to find a GOOD OMP...Post a Wanting to BUY in the Sec Gen FOR sale Section and also the "regional" For Sale sections of the Forum,Someone May have one.and it wil save you from Buying from the "stealership"..Good Luck.,sTYX.
Old Aug 9, 2009 | 08:19 AM
Banzai-Racing's Avatar
Rotary Specialists
You don't pull the codes with a scanner, here is a how-to along with the codes and what they mean http://www.banzai-racing.com/FD_S5_error_codes.htm
Old Aug 9, 2009 | 10:34 AM
Aaron Cake's Avatar
Engine, Not Motor
Not sure what this has to do with jack stands, but OK.
An ODB1 scanner won't help you.
No. The ECU must see a functional metering oil pump or it will go into limp mode.
Old Aug 10, 2009 | 07:20 AM
IN
ik thanks, the jackstand thing if I put it on the stands I can go 1st 2nd 3rd 4th 5th up in 100 plus mph but once it hist the pavement we have problems.
Old Aug 10, 2009 | 07:21 AM
IN
thanks
Old Aug 10, 2009 | 07:22 AM
IN
thanks!!
Old Aug 10, 2009 | 01:13 PM
DriftBizzle's Avatar
Its probobly LimpMode.. which means it has an OMP failure.... Replace the Oil Metering pump... Limpmode BE gone! =)
Old Aug 10, 2009 | 01:14 PM
I say this because same thing happened to my friend.. Replaced OMP.. Car runs Beautiful now..
Old Aug 12, 2009 | 07:24 AM
thanks everybody let you know when I check these things out and get them replaced
Old Oct 5, 2009 | 09:19 PM
450riden's Avatar
A failed OMP on a S5 will more than likely take the ecu with it
Old Oct 7, 2009 | 07:01 AM
so I have herd just saving money for the parts for it now thanks yo
Old Oct 8, 2009 | 01:27 AM
w.sen's Avatar
In a Bucket
Does an s4 omp controled by the ecu?
Snook
Aug 17, 2015 12:59 PM
Junkee
Aug 15, 2015 01:57 PM
Marty RE
Aug 13, 2015 11:19 AM
