Turbo sizing advice
Old Jul 10, 2009 | 11:56 AM
turbine's Avatar
Turbo sizing advice
need advice on getting a new turbo for my fc.
i originally had a switzer s300 with a 61 mm compressor and a 110 hot side
i have a s4 motor with a half bridge port
i am looking to make 500 whp on pump and meth injection and 600 plus on race gas
bullseye power wants to sell me a bullseye power 372. 72 mm compressor with race cover and a 110 hot side?
anyone running this turbo?
hows the spool time and will it make the power i am after
thanks
Old Jul 11, 2009 | 10:07 AM
turbine's Avatar
also bullseye wants 1300 for it? is there anything different from a bullseye 372 then Borg Warners 372
they say theres come s with a race cover.
with a half bridge and a 4 inch exhaust can i see a bar of boost by 3500?
Old Jul 13, 2009 | 10:33 AM
ScorpionT's Avatar
Bullseye has some of their own parts now, but they use mostly BW parts. Their race cover is their own casting, and its a little different than the BW one. Depending on the turbine 1 bar of boost might be possible.
Old Jul 13, 2009 | 08:48 PM
turbine's Avatar
what turbine would you recommend?
Old Jul 13, 2009 | 11:41 PM
ScorpionT's Avatar
The 83 or 87mm. Either one works good, and with only a half bridge the 83mm should still be enough to do the job. If you want to squeeze out more power and revs the 87mm is better, but it does cost more.
FD7KiD
15
Feb 26, 2021 10:12 PM
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
