to boost or not to boost?
Old Jun 24, 2009 | 01:56 PM
90gtu-s's Avatar
rotaryninja
OR to boost or not to boost?
i have a 90 gtu and i am debating weather or not to do a t2 swap or just rebuild the 13b n/a. i want to make it more suited to drifting or auto cross so any info would be much appreciated. i know that a n/a is quicker through corners. i also had a question about lsd's and welding the gears. is it a good route to go or should i just spend the money and get a true lsd either 1.5 or 2.
Old Jun 26, 2009 | 04:25 PM
rx7freak13v's Avatar
ur gtu should have came with an lsd.im pretty sure only the base models came with an open diff?as for drifting i would agree to stay na and port.
Old Jun 26, 2009 | 04:31 PM
project3328's Avatar
if ur drifting definatly get the 2 way ull love it
Old Jun 27, 2009 | 08:45 AM
trblsmeFC's Avatar
not true on the lsd in GTU, it did come on the GTUs, look for the lsd tag on the rear to know if you have the lsd or not,
as for porting read up on porting the 6ports, you would need the 4port turbo housings to port the exhaust, and you can only slightly enlarge the intake ports on the 6 port,
read, read, read, and read some more
Old Jul 1, 2009 | 08:55 PM
drift slut_fd's Avatar
Team HND
cusco makes a really good 2 way lsd that would make the world of difference for drifting but keep in mind that 2 ways have are susposed to lock up during hard down shifts plus are kinda loud and hard hitting......if your car is a daily driver i wouldnt put it on
Old Jul 3, 2009 | 10:31 AM
Chillski's Avatar
i am drifting a 90 gtu's as well and i been thinking about getting the kaaz lsd... my stock lsd has to many miles on it already and it hasnt been feeling right lately.
Old Jul 5, 2009 | 03:14 PM
hugeturbolag's Avatar
boost away
Old Jul 5, 2009 | 03:24 PM
maac0953's Avatar
why would you say the NA is better around corners OP?
id rather have boost so i can power my way threw the drift.
87TII
Old Jul 7, 2009 | 10:05 PM
flaco's Avatar
rebuild it you will have more fun and you will know what u really got
Old Jul 9, 2009 | 11:20 PM
90gtu-s's Avatar
rotaryninja
OR
87TII
well the reason i say that is due to turbo lag and i tend to listen to what keiichi tsutchia has to say lol. yeah i love turbo power but i also love my na hahaha. who knows maybe ill find a gutted rx and swap my current engine into that after its rebuilt and just do the t2 swap to the gtu. alot of things are still up in the air.
Old Jul 9, 2009 | 11:45 PM
Djonyx's Avatar
I'll stay N/A for simple set up. A lot of turbo guy's running high power are having problems, specially on a hot and muggy day. Now once you are ready for higher power and torque look into 20b N/A set up, for reliability. I wish I can build a four rotor N/A, I just love the way it sound. http://www.youtube.com/watch?v=JaAKO...eature=related
Old Jul 9, 2009 | 11:50 PM
Discokid's Avatar
My first rotary project..
It really depends on your style of drivin dawg. N/A's are really easy to control on the turn in but lack in the exit and turbo are a lil sluggish in the entrance but excell in the exit. Now I can tell you, nuthin pisses me off puttin all this work in leavin someone in a corner just to have him on my *** again right after we exit.
There is no "dominant" rx-7, you have to discover your stlye.
As for lag, our cars really dont suffer from the same lag as other cars do.
If it comes down to Tsuchiya himself, see what he says about that blue FD Amemiya Rx7. That thing had 350hp and dominated when it got over 400hp its still was a very dominant car (eventually losing to the S2000 in a tough race) for being a turbo.
Driftin is really different between N/A, Supercharged to Turbo. You should hook up with some friends that have different aspirations and try em out before you make a solid decision, so you wont regret it.
All Im tryin to say is discover your style, and build on it. I hope this helps you dawg...
Old Jul 10, 2009 | 04:00 PM
Hangerbaby's Avatar
I love the boost, go with the boost
Old Jul 10, 2009 | 06:27 PM
Big Papa Jefe's Avatar
+1. Love it!!!
Old Jul 10, 2009 | 11:45 PM
Hangerbaby's Avatar
I guess for drifting it could always come down to preference? I'm not one to drift though so I could be wrong. Of course by not one to drift, I mean "can out drift anyone, ever"
:P
Old Jul 11, 2009 | 10:31 AM
Aaron Cake's Avatar
Engine, Not Motor
What a train wreck of a thread...
"Drifting or autocross". That is the first problem. In autocross, cars need to be set up to handle. In drifting, it is the opposite. So you need to make the decision first before money is wasted on the car...
If the NA drivetrain is in good shape, and the car runs well, then drive it as is for a while. I'm sure you will find that it is fun enough. Then maybe later, when you have some experience under your belt, the TII swap may be the way to go.
Old Jul 16, 2009 | 03:07 PM
funkjaw's Avatar
After driving a modded N/A for two years I know how fantastically fun they are to drive. Now I own a turbo 2 S5 that I have been driving for a couple of months. And wow the power makes a huge difference. I'd say if you are going to put any money into the car GET THE TURBO!!! It is absolutely not worth it at all to put thousands of dollars into a non turbo motor. Its almost stupid.
+1 for boost.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
