car wont hold idle
Old Jun 21, 2009 | 10:56 AM
jsayers's Avatar
R.I.P. Mark
car wont hold idle
The car starts and runs for a few seconds then the rpms drop down and the car dies. if you hold the throttle around 1500 it will stay running. As soon as you let off the throttle the car dies. It is a 88 s4 na, completely stock. Any ideas on what could be wrong?
thanks
Old Jun 21, 2009 | 08:51 PM
katkaroto's Avatar
dewey
had the exact issue on my 88 that i just sold. never figured it out...
Old Jun 22, 2009 | 06:59 PM
jsayers's Avatar
R.I.P. Mark
bump
Old Jun 23, 2009 | 09:55 AM
nyvan's Avatar
mine does the same. 87 TII. trying to figure it out as well, will let u guys kno if i find anything out
Old Jun 23, 2009 | 11:58 AM
Chuck's Avatar
Sounds like a big vacuum leak and they can be tough to pin down. Check all the obvious places like the vacuum hoses for tight fits at each end and no cracks. Then the gaskets between UIM and TB and the UIM to LIM. You can also develop vacuum leaks at the fuel injectors. Fix the vacuum leak and your problem should go away.
Old Jun 26, 2009 | 01:03 PM
jsayers's Avatar
R.I.P. Mark
I can't find any vac. leaks, I cleaned the bac valve, put in new spark plugs and replaced the old thermostat and the problem still hasn't went away..
Any other ideas on what this could be?
Old Jun 26, 2009 | 02:29 PM
Chuck's Avatar
It really sounds like a vac leak, but if you're sure it's not then the next thing to do is verify the setting and function of the TPS. And make sure your idle speed is correctly set.
Old Jun 26, 2009 | 03:22 PM
ultrataco's Avatar
r o t a r y
I had a similar problem. Turned out to be my injector grommets. Mine were missing, which caused a huge vac leak. Yours may be cracked or worn out which can also cause a leak.
Old Jun 26, 2009 | 04:49 PM
rx7freak13v's Avatar
i had the same prob with my 88 na,it was the afm,i swapped it out and it ran just fine.try it out
Old Jun 26, 2009 | 10:04 PM
FCmidnight Blue 88's Avatar
You need to adjust ur throttle.. I been having the same problem off and on but each time i make a small adjustment on the screw on the side of the throttle it gets better and i havent stalled yet on a cold start for about a day now... yesturday i was stalling a lot till i made that small adjustment in the throttle... check out my other thread rotaryrocket member has posted a link in my other thread on how to make the adjustments... thats what u need to do like i have to.... To find thread just look for it.. it's title 13b 6 port intake.
Old Jun 26, 2009 | 10:41 PM
if u can't find my other thread.. here's the link..... http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1
RotaryRocket member gave me this link.
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
sYnth.
Aug 17, 2015 07:28 PM
ncds_fc
Aug 15, 2015 10:06 AM
