T2 trans in FB, working on it now
Old Jun 1, 2002 | 05:42 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Well I started working with my T2 trans in my 85. Looks like theres not much to mod at all.. The stock metal part that bolts to the trans has to be remade, maybe.. Its a piece of metal that looks like a big C metal piece, but straight instead of the curves like in a C. Other than that the stock rubber piece looks like it fits fine. It appears its maybe 1/8-1/4" difference. Actually hacking the rubber part a little looks like it would work?
Wheres setzep when I need him, anyone else do this...
Also I dont see the need for the spacers that others have used. Bolt the stock crossmember up there, with the rubber piece on there, and that stock metal piece that bolts to the trans (2 12mm bolts), seems to fit?
Battery is dead in the camera so Im bumming on pics for today....
Old Jun 2, 2002 | 02:41 PM
MIKE-P-28's Avatar
Oh setzep where are you?
Old Jun 3, 2002 | 01:13 PM
MIKE-P-28's Avatar
Ok guys this is a direct bolt in, a little rubber trimming and its A OK
Old Jun 3, 2002 | 01:48 PM
zyounker's Avatar
root
They why mine is done is i bought some spacers from autozone, for some truck suspension..
You might be able to get rid of/make a new mount for it though.. it is only about 1 inch offf..
You will need to drill holes in the TII mount to bolt it up too..
-Zach
Old Jun 3, 2002 | 01:49 PM
zyounker's Avatar
root
BTW i might have a mount made at a machine shop to make it a true bolt on job..
Let me know if anyone is iterested.. I am worried mine is gonna shift when i try to put some power down..
-Zach
Old Jun 3, 2002 | 02:14 PM
abeomid's Avatar
i'm taking my tranny out to change the input bearing, should i just put the TII tranny in since i'm doing the TII engine swap October???
things I will need are:
1. TII Tranny
2. TII flywheel and counterweight
3. TII clutch assembly
4. TII driveshaft
Is that all????
Old Jun 3, 2002 | 02:29 PM
MIKE-P-28's Avatar
I dont see the complication, I just used my old 85 crossmember, my piece that bolted to my trans, and the rubber piece trimmed 1/8" and BAM it fits perfect
Old Jun 3, 2002 | 02:31 PM
MIKE-P-28's Avatar
1. TII Tranny
4. TII driveshaft
Is that all????
Yeah all that will be fine with a 13bt, just swap the shifter housing onto the t2 trans, ask about cutting the t2 rod when you get there...
Old Jun 3, 2002 | 02:54 PM
abeomid's Avatar
So I need to change the counterweight in the front of my engine, right? The water pump has to come off???
Old Jun 3, 2002 | 03:06 PM
MIKE-P-28's Avatar
If you swapping to a T2 in October, Id wait. If you go mixing front and rear counterwights, you better be sure they are balanced...
Yeah to change the counterweight, front water pump housing, front cover, oil pump chain etc has to come off..
Old Jun 3, 2002 | 03:07 PM
zyounker's Avatar
root
Yeah, you will need to pull off your front cover and waterpump..
Also be carefull you do not loose/misalign your thrust bearing.
Check out http://www.mazdatrix.com/faq/pulley.htm
-Zach
zyounker's Avatar
root
And mike is right.. don't do the swap untill you are really ready to do it..
-Zach
Old Jun 3, 2002 | 03:11 PM
MIKE-P-28's Avatar
-Zach
If you go with a 13bt, then swap out the thermal pellet thingy with either an Atkins or Mazdatrix plug.. I didnt have a way to measure end play, when you swap the front and get it back together make sure when you pull the front pulley back and forth you got a SMALL amount of play. I think the end play is .0015-.0018 inches
Old Jun 3, 2002 | 05:53 PM
peejay's Avatar
Old [Sch|F]ool
Waitasec... Why are you changing the front counterweight?
Old Jun 3, 2002 | 07:45 PM
moremazda's Avatar
Gone Race'n
When you remove the stock flywheel infavor of an aftermarket one that requires the automatic counter weight, you need to use the counter weight FOR THE ENGINE, not the tranny. The flywheel is chosen to fit the tranny, not the engine. IE a T2 tranny onto a 82 12a, would require the 82 12a counter weight and the T2 flywheel and clutch.
Ryan
Monsterbox
Jul 29, 2022 10:48 PM
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
NoMorePoison
11
Aug 18, 2015 11:18 AM
