broken water pump housing and over heating.
Old Jun 17, 2009 | 12:13 AM
no_luck's Avatar
hello all i am no luck and i have a 1988 mazda rx7
i guess i mis aligned the thermastat and tightened the water kneck and it broke.
i got the water pump off and im down to just the housing and i got the one side loose but the other side on the passanger side is stuck on the stud i dont kno i hit it with a hammer pb blasted the **** out of it. heated it and everthign it wont budge what can i do ? please help asap
the car also over heated the gauge didnt ping on H but it got hot
and there was coolant in the rear of the engine did i blow my cool seals?
Old Jun 17, 2009 | 05:15 AM
slpin's Avatar
7th Heaven
hello i am slpin and i have no luck reading your lost take some pictures and maybe we could guess what you are saying pictures are worth a thousand words and i can see why check the hose from firewall to the back of the engine under the oil filter
Old Jun 17, 2009 | 09:35 AM
87 t-66's Avatar
not a drifter
take the pulleys and all bolts on the waterpump housing off and it should come right off. maybe tap the back with a rubber mallet but it should come off easily.
where in the rear of the engine? inside the rotor housing?
Old Jun 17, 2009 | 10:48 AM
no_luck's Avatar
http://www.rx7turbo.com/haltech/waterpumpafter.jpg
i cant take a pic but i have this on google. anyway the water pump is complety off. i just cant get the housing off it stuck on one the 12 mm studs.
i tried heating it up and hitting it with pb blaster and everything. and the coolant seems to be puddling on the trans mission like on top
i hope i make more sense
Old Jun 17, 2009 | 02:56 PM
no_luck's Avatar
ok i got the housing off finally
i had to take off the stud with a pair of locking pliers
there was a bunch of gunk that made it impossiable to remove
Old Jun 17, 2009 | 03:32 PM
87 t-66's Avatar
not a drifter
you probably have a busted hose thats leaking coolant if its on top of the transmission. more than likely one of the heater hoses or one that goes to the TB/BAC.
Old Jun 17, 2009 | 05:08 PM
arghx's Avatar
rotorhead
remember that there are waterpump shims for the housing, don't forget those or there will be big problems later
Old Jun 17, 2009 | 08:59 PM
no_luck's Avatar
well unless i missed it as i was pulling everyhting off i didnt see any shims
but i am buying everything off mazdatrix. im just worried that i blew a seal.
and i used a fan from a lincoln mark vIII .. well the car didnt over heat but started bogging and running rich. so that makes me even more paranoid.
this is my first rotary
Old Jun 17, 2009 | 09:00 PM
no_luck's Avatar
thanks for helping me
means alot
Old Jun 18, 2009 | 10:55 PM
no_luck's Avatar
ok so i went to mazda
ordered the parts came out to a easy 38.73
for those who will llater look at my thread here are the part numbers
for everything.
8af1-15-171-9u== thermostat and gasket
m326-15-168===the shims for the housing
n326-15-162===water pump housing to block gasket
n3y3-15-116===waterpump gasket
and for those who need a stud kit here is the part number for the water housing studs
1757-10-208
Old Jun 19, 2009 | 12:58 PM
slpin's Avatar
7th Heaven
so do you have any moire problems now?
a thermostat is the rfirst thing yoiu want to replace... i see you did that... goo djob
Old Jun 19, 2009 | 01:36 PM
no_luck's Avatar
well all of my gaskets came in today except the water housing gasket.
i hope my teacher has a housing for me on monday so i dont have to go to the junk yard and take one out.
so i will let yall kno my progress as i get updates the only thing is i wish i had a digital camera(broke mine in a car wreck)
Old Jun 27, 2009 | 08:36 AM
no_luck's Avatar
just a update
i got everything back together finally. ah it was easy thanks to the manual .
i haven't driven it but i did get it started she doesnt over heat or anything which is good so far.
i added a dye and check no leaks and there is no florescent colors in my exhust pipe.
next stop is to do the champagne test to check my coolant seals
thanks guys you've been a great help
Old Jun 27, 2009 | 06:00 PM
texFCturboII's Avatar
version 2.0
Just a friendly tip:
You don't need to remove the entire water pump housing just to replace the thermostat housing / coolant neck. It's 2 bolts. 3 if it's a series 5.
Old Jun 27, 2009 | 08:26 PM
no_luck's Avatar
my housing broke i had to change the whole thing
Old Jun 27, 2009 | 09:59 PM
version 2.0
Ahhhh... that makes much more sense.
Old Jun 27, 2009 | 10:31 PM
BonesZ33's Avatar
Glad you've been able to figure it out. You're metal water pump housing broke?. you said because you overtightened it?..
Take some pictures we like pictures
Old Jun 30, 2009 | 01:11 AM
no_luck's Avatar
ill try and get pics soon ...
oh **** let me get it out of the trash lol sorry
oh and now i need a starter
FD7KiD
15
Feb 26, 2021 10:12 PM
sherff
Feb 24, 2019 12:09 PM
FD7KiD
Aug 17, 2015 11:50 PM
