Street-porting boundaries
Old Jun 11, 2009 | 12:58 PM
Justen's Avatar
I'm doing my own backyard rebuild, on my first rotary. I'm in the process of porting my end plates and mid iron.
I know how spreading the intake opening in different directions affects the timing and power band and such...
What i want to know is how much room for error do you have and the inside edge of the port (closest to the e-shaft) without leaking oil? .... Cuz i nicked that edge and had to sand it out a little but not much.
Any one have any pictures of port jobs that caused an oil leak?
Old Jun 11, 2009 | 03:11 PM
peejay's Avatar
Old [Sch|F]ool
As a rule, you shouldn't touch that edge, ever.
In practice, if you measured the oil seal track, you might see about .5mm of extra port area you might be able to get. IMO that's really not worth the bother.
Old Jun 11, 2009 | 11:56 PM
Justen's Avatar
I'm probably about 1 mm over the OUTSIDE wear mark... Isn't it the INSIDE diameter of the seal that would cause a leak? Shouldn't the thickness of the oil ring still overlap the port without spilling oil from the inside diameter?
And how much oil are we talkin bout here? Enough to foul the plugs?
Old Jun 11, 2009 | 11:59 PM
Justen's Avatar
The whole reason why I pulled the motor was cause my oil control rings were shot, car used to smoke like a damn chimney...
now i'm worried about burnin oil from the same frickin seal. Ironic? :/
Old Jun 18, 2009 | 12:20 PM
Jeff20B's Avatar
Lapping = Fapping
Oil rings usually die fast if you have your side plates resurfaced without renitriding. I wonder how many shops are still recommending that silly service?
Ian_D
Oct 14, 2015 12:31 PM
Hullie
Old School and Other Rotary
Oct 13, 2004 07:37 PM
untaymd
Aug 11, 2002 09:41 PM
