DIY Completed: Brakes, Rotory Engine Overhaul, Suspension alignment, air bags, etc.
Old Jun 4, 2009 | 11:10 PM
Spartanic's Avatar
Just in case you guys are interested here are some DIY writeups completed for the 1993-1995 Mazda RX-7. Let me know if you guys see any errors.
- Air Bags. Mazda RX-7 1993-1995 FD3S.
- Air Conditioning. Mazda RX-7 1993-1995 FD3S.
- ABS system. Mazda RX-7 1993-1995 FD3S.
- AC compressor servicing. Mazda RX-7 1993-1995 FD3S.
- Cooling system specs. Mazda RX-7 1993-1995 FD3S.
- Differential overhaul. Mazda RX-7 1993-1995 FD3S.
- Disc brakes. Mazda RX-7 1993-1995 FD3S.
- Drive belt adjustment. Mazda RX-7 1993-1995 FD3S.
- Electrical component locator. Mazda RX-7 1993-1995 FD3S.
- Engie cooling fans. Mazda RX-7 1993-1995 FD3S.
- Front Suspension, ball joints, wheel bearing, etc. Mazda RX-7 1993-1995 FD3S.
- Fuses and Circuit Breakers. Mazda RX-7 1993-1995 FD3S.
- Starter. Mazda RX-7 1993-1995 FD3S.
- Jacking and hoisting. Mazda RX-7 1993-1995 FD3S.
- Maintenance info. Mazda RX-7 1993-1995 FD3S.
- Manual Ac and Heater systems. Mazda RX-7 1993-1995 FD3S.
- Steering system, power and pinon. Mazda RX-7 1993-1995 FD3S.
- Alignment procedures. Mazda RX-7 1993-1995 FD3S.
- Rear Suspension, wheel bearings, control arms, etc. Mazda RX-7 1993-1995 FD3S.
- Ride height adjustment. Mazda RX-7 1993-1995 FD3S.
- Steering Column. Mazda RX-7 1993-1995 FD3S.
- Rotary Engine Overhaul. Mazda RX-7 1993-1995 FD3S.
- Wheel Alignment specs. Camber, toe, caster, etc. Mazda RX-7 1993-1995 FD3S.
More updates coming soon...
Old Jun 5, 2009 | 12:52 AM
RLaoFD's Avatar
Brappable not Unflappable
this will surely help out a few ppl.
Old Jun 5, 2009 | 04:28 AM
EFS.O's Avatar
Congrats,this is a must for any Fd owner!!!
Old Jun 5, 2009 | 12:08 PM
Prometheus's Avatar
Still got it.
The diff. case & oil pan should not used as jacking points.
Old Jun 5, 2009 | 12:11 PM
catch-22's Avatar
sticky time!
Old Jun 5, 2009 | 12:17 PM
Julian's Avatar
I hope he was trying to indicate the cross member. Now, i know its not right but i have jacked my Fd on its diff. housing for 14 years.
Old Jun 5, 2009 | 12:27 PM
gracer7-rx7's Avatar
needs more track time
Um, why not just get this info from the FSM?
You can even open it in the garage and drop it a few times w/o breaking the laptop screen.
Old Jun 6, 2009 | 10:07 AM
Socamoto's Avatar
Im pretty sure the service manual says to jack on the crossmember/front subframe and diff...
I use the diff and theres no problems...
Old Jun 6, 2009 | 03:51 PM
dguy's Avatar
There's nothing wrong with jacking the car up from the diff case, just use an aluminum jack or a pad to prevent fin deformation.
Old Jun 6, 2009 | 06:04 PM
dgeesaman's Avatar
How is this different from the FSM?
Old Jun 7, 2009 | 10:46 AM
oo7arkman's Avatar
In the Garage
Bingo. I do the same, just protect it a little like it has been mentioned.
Old Jun 8, 2009 | 05:29 PM
Spartanic's Avatar
If you guys are worried about causing damage then use a wooden block or a bunch of dirty shop towels under the jack to the diff.
Old Jun 9, 2009 | 01:22 PM
TimeMachine's Avatar
Bosozoomku
Another great thread, thanks OP!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
rx7jocke
Aug 15, 2015 03:36 PM
