Does this WG porting look too big?
Old May 27, 2009 | 06:44 AM
staticguitar313's Avatar
R.I.P. Icemark
Cars only making 5lbs on a streeported full non-sequential setup . . .
Old May 27, 2009 | 07:42 AM
puma's Avatar
canadian monster
it doesn't look too big but close the flap, if you can't see on each side, that shouldn't be your problem.
Old May 27, 2009 | 07:47 AM
rd_turbo's Avatar
ERTW
If you did a hose job while down there, make sure you didn't inadvertenly toss the hoses with the restrictor pills in them. That would put you closer to 7 psi, but still worth a look. Put some machinist's dye or paint on the flap and take an imprint with it closed. You don't need much overlap, but you can't see any gaps.
Old May 27, 2009 | 05:08 PM
R.I.P. Icemark
I Went to the very edge and there a crack near the back, so I'm sure that isn't helping. Also I did toss the restrictor pills because I thought with a electronic boost controller they should be removed from the lines. . .
Old May 28, 2009 | 03:27 PM
G's 3rd Gen's Avatar
That is fine. Almost all wastegates I've seen w/ a few miles on them have that crack. Your boost problem is not due to the port job. Mine actually is a bit more than that by eyeballing the smooth edge. G
Old May 29, 2009 | 12:36 AM
R.I.P. Icemark
Thanks a lot for the support guys I'll be tracking down this boost leak tonight.
Old May 29, 2009 | 11:20 AM
cptpain's Avatar
Torqueless Wonder
is that a huge crack i see?
Old May 29, 2009 | 03:30 PM
R.I.P. Icemark
yeah . . . it is >_>
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
chiefmg
Sep 10, 2015 07:46 AM
doritoloco
Sep 5, 2015 12:41 PM
