parallel turbos?
Old May 30, 2002 | 05:26 PM
sinfestboy's Avatar
parallel turbos?
would it be practical to run parallel twin turbos? it seems that it would have the responsivness of a stock twin, and it could (?) support the power of a big single.
but would it cost too much?
Old May 30, 2002 | 05:31 PM
Rotarius's Avatar
You bet it will cost twice as much and it will probably be more laggy than the stock twins and could posibly make morepower than single. It all has to do with turbo selection (housings, comp. configuration ect.).
Old May 30, 2002 | 05:39 PM
sinfestboy's Avatar
do you think 500 hp would be possible with lag only maby 1-2 sec more than stock?
Old May 30, 2002 | 05:49 PM
Rotarius's Avatar
500 hp is posible, +1-2 sec. lag could be acomplished but it all has to do with what size turbo you pick. also you have to plan first what do you want to do with the car (drag, autocross, show) then you take it from there. To give you an ecenario- you both take of at the same time but the guys next to you has a single turbo and he reaches powerband 1 sec. faster jumping 3/4 car lenghts infront of you.... thats how 1/4 mile races are won..... just a thought
Old May 30, 2002 | 06:00 PM
sinfestboy's Avatar
singles have more than 2 sec lag! the point of the parallel twins is that it has less lag, and can produce same amount of power, if not more.
Old May 30, 2002 | 06:12 PM
Rotarius's Avatar
Do you mean parallel as non-sequential?
Old May 30, 2002 | 06:15 PM
Rotarius's Avatar
Think of building an aftermarket twin sequential system with all the pipes ,gates actuators ect..... umm..... $$$
Old May 30, 2002 | 10:29 PM
kwikrx7's Avatar
There's a little lag from running parallel or non-sequential but it's not terrible. You can run a little more boost through parallel twins since they don't create quite as much heat as the aequential setup. There's more midrange and high-end power but low-end suffers a little. Running upgraded twins parallel (which I've seen only 1 other person on the forum do) would be like running a medium sized single.
Old May 30, 2002 | 10:32 PM
sinfestboy's Avatar
Oh, Im not planning to do it, I just wanted to know about it. Juuuuuuuuuuuuuuuust incase I run into some money anytime soon
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
