Introduce yourself New members post about yourself here...
Noob Alert
Old May 23, 2009 | 08:42 PM
Zukied's Avatar
Noob Alert
Hola, Im 100% new to rotaries just bought a rx7 10/83 Gs model, worked on basically everything else execpt a rotary and just love how the 1st gens look. plans are take off a/c and cruise control, lsd ,electric fan and new radiator, header , Manifold and carb not sure what to go with on that maybe you guys have some opnions, Id like to go pretty radical, i hear all about bridgeport/streetport and a carb swap, i have a couple quick questions about the streetport/bridgeport when you want a bridgeported motor is it the manifold? is that all thats done? and say if i do a carb swap im hearing about having to mix my oil. That really dosent bother me atall.just like to know if its true Just the basics when it comes to manifold/carb swaps would be fantastic, i hear webber, mikuni holley ,sterling, . Thanks Ill try to have some pictures posted tomorrow and a little build as i go along . Thanks and i hope to hear some good info and carb and manifolds
Old May 23, 2009 | 09:32 PM
mar3's Avatar
Administrator
Eh, yer looking at the high end of things folks do to 12A rotaries. You need to start with your exhaust system. The bridgeport mod isn't a bolt-on affair, it refers to a special porting procedure done to the engine's internals itself. IOW, the engine has to come completely apart to get a bridgeport job done. Best to work with exhaust, then suspension upgrades before you dive into the engine itself, IMHO.
Mario III
Old May 23, 2009 | 09:44 PM
maac0953's Avatar
welcome
Old May 23, 2009 | 10:49 PM
Zukied's Avatar
Ok thats what i was wondering if it was bolt on ordeal, what about streetport? and stock port, same thing motor has to come apart? Obviously exhaust and the minor things will be first. im just trying to figure out a build here. Also i found a mikuni dual side draft carb and manifold, anybody have any luck or know anything about these?
also have people had better results using the stock shroud or just using the fan without a shroud. Im just a very fast worker, i like to get my toys and tear em apart and get em back together as quick as possible so i can play, i hope to have "everything" ordered by the first weekend in june
Old May 24, 2009 | 09:03 AM
Zukied's Avatar
nothing wrong with that, we all have different needs/wants for our cars
Old May 24, 2009 | 01:12 PM
sdolla86's Avatar
WElcome!
Old May 24, 2009 | 10:41 PM
mar3's Avatar
Administrator
Stock port is just the engine as it came from the factory. Streetport is the equivalent of a simple bowl blend in a cylinder head from a piston engine, except, of course, that there is no cylinder head on a rotary. So, yes, the engine has to come apart for a streetport job. For the rest of the questions, go ahead and C&P your post in a new thread in the New Member Technical board where it's more appropriate.
..and welcome aboard!!
Mario III
Old May 27, 2009 | 05:10 PM
dcheyne55's Avatar
welcome
Old May 30, 2009 | 08:20 PM
Rx KrueGeR's Avatar
86 GXL AND LOVING IT!!!!!
welcome!
Old May 31, 2009 | 01:14 AM
Chiba Kun's Avatar
Beinvenidos
whinin
Mar 30, 2019 07:53 PM
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
RXeckless
Sep 12, 2015 04:52 AM
johnchabin
Oct 1, 2002 12:04 AM
