My 7 is burning rich (cat is glowing)
Old May 6, 2009 | 08:10 PM
RX7JIM86's Avatar
AZ My 7 is burning rich (cat is glowing)
I have an 86 RX-7 N/A and it's burning very rich. I have replaced the fuel dampener, fuel injecters and also the trailing coil. The coil was miss firing. It is still running rich and the cat is glowing after only 5 minutes of the car running. The cat and mufflers are new also. Any Ideas?
Old May 7, 2009 | 10:45 AM
Aaron Cake's Avatar
Engine, Not Motor
Well, a full tuneup is a good place to start. Plugs, wires, filters, etc.
Test the operation of the ECT as per the instructions in the FSM.
Test the AFM as well.
You can pull the plugs and determine the condition of the engine. They should be a tanish with maybe some black deposits. If they are black and sooty, the engine is rich. If only one plug is black and full of soot, then that rotor is the issue. Black and oily would indicate an oil o-ring failure.
Old May 7, 2009 | 11:27 AM
Kentetsu's Avatar
Make sure you still have spark on the lower spark plugs too. Highly retarded timing, or loss of leading ignition, will cause this...
Old May 7, 2009 | 01:04 PM
RX7JIM86's Avatar
I did the full tune up also and it didn't help, new plugs, K&N air filter, wires.
I will test the ECT and the AFM.
Thanks for the info, I will let you know how it goes and ask if there is any thing else I need to look at.
Old May 7, 2009 | 01:06 PM
RX7JIM86's Avatar
I will test the ECT and the AFM. I will also check the leading coil as well
***SORRY, I DONT KNOW WHY THIS POSTED TWICE***
Old May 7, 2009 | 03:26 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes, check for leading spark as suggested above. I forgot to mention this.
Old May 8, 2009 | 04:48 PM
RX7JIM86's Avatar
I checked the leading coil and its ok, also the ECT is ok, How do I check the MAF sensor?
Old May 9, 2009 | 12:59 AM
black1991's Avatar
metal collector
which cat is glowing the pre or main and is the replacement oem or aftermarket
Old May 9, 2009 | 10:14 AM
Aaron Cake's Avatar
Engine, Not Motor
The FSM has procedures to check the AFM.
Old May 9, 2009 | 12:29 PM
RX7JIM86's Avatar
It's the main cat that is glowing, I'm not sure if it's OEM or not, what ever the muffler shop put on it.
Old May 9, 2009 | 02:18 PM
unren's Avatar
they might have put in a cat that cant handle the rotary's heat.
Old May 14, 2009 | 03:30 PM
RX7JIM86's Avatar
Thanks for all the info, my 7 is now running smooth. It's great to know that anyone with an rx7 can get help with anything RX7. Thanks again. Now it's time to do the body work and paint job.
Old May 14, 2009 | 08:30 PM
buj818's Avatar
How did you fix this (if ya dont mind me asking) =P And congrats!
Old May 17, 2009 | 01:33 AM
NoPistons!'s Avatar
Tango Down
Glowing cat?
I'd fix that by promplty replacing it with a test pipe and selling the cat to some hustler.
Old May 18, 2009 | 11:07 PM
black1991's Avatar
metal collector
btw if the 2 cats are stock and full their worth $110 right now
ls1swap
Jun 3, 2024 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
