what size differental does a 85 gs 12a have
Old May 28, 2002 | 03:45 PM
minocqa's Avatar
hi
what size differental does a stock 85 gs 12a have?
Don
Old May 28, 2002 | 04:42 PM
peejay's Avatar
Old [Sch|F]ool
Standard Mazda 7", just like RX-2, RX-3 SP, '94-up Miata, and the front of some trucks.
Old May 28, 2002 | 10:44 PM
Kill No Cone's Avatar
The 85 Rx7 (GS, GSL, and the GSL-SE) will have the larger axle rear ends. You can tell by measuring the housing around the wheel bearing. If it is close to 3 1/4" it has the larger axle. If it is about 2 7/8" it is the small axle. The key thing is if it is a GSL-SE, which has a different length axle (for the added offset) and a different bolt pattern. You can use the third member from a GSL-SE in any 84 or 85 Rx (and it has a slightly lower gear ratio).
Hope that is helpful
Old May 28, 2002 | 10:56 PM
minocqa's Avatar
who makes the aftermarket?
what i'm looking for is a little quicker 0 to 60
any suggestions?
Old May 28, 2002 | 11:00 PM
peejay's Avatar
Old [Sch|F]ool
Check out members.aol.com/solomiata and look under drivetrain information.
Old May 28, 2002 | 11:07 PM
minocqa's Avatar
thanks Peejay
Old May 28, 2002 | 11:21 PM
JEB Thornton's Avatar
You can also contact SelectMaz in Austrailia for a great price on used ring and pinon sets.
Old May 29, 2002 | 01:59 AM
V8kilr's Avatar
go for a gsl-se swap,
you will get bigger gears and an award winning lsd
check out my write up on it
click me
Old May 29, 2002 | 11:17 AM
peejay's Avatar
Old [Sch|F]ool
GSL-SE only has 4.08 or so gears - not really worth the swap IMO. They're not any larger either - same ol' 7".
I say scrounge some 4.30's or 4.444's out of a Miata or 4.778's out of a Kia!
Old May 29, 2002 | 10:21 PM
twister's Avatar
Kia - any contact details please.
I am still after a 5:1
Thanks
Old May 29, 2002 | 11:25 PM
Ya, Peejay, can you tell me more about the Kia swap?
Shainiac
Jul 17, 2019 02:20 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
