A little help for a young rotory enthusiest
Old May 28, 2002 | 10:48 AM
I have an 81 RX-7 and I have owned it for 1 year the engine was rebuilt 40,000 miles ago. I was on a long drive and when I was going up a hill in higher RPM's it backfired 10+ times and then died.. Now it barely runs only with the choke fully engaged. I need a direction to folow to fix my problem.. Any help would be greatly appreciated.
Thanks Kevlar
Old May 28, 2002 | 10:52 AM
damon's Avatar
sounds like vaccum or compression to me
Old May 28, 2002 | 10:53 AM
yayarx7's Avatar
Are you Nucking Futs?
I would get a compression test on the motor. Then go from there.
Do a search and there are several threads to help you out on this.
Old May 28, 2002 | 10:39 PM
Kerry's Avatar
Since it will run (sorta) with the choke, it's probably lean, ie, not enough fuel or too much air. Look for any vacuum hoses disconnected, then see if the carb is getting fuel. You can see if the carb has fuel in it by looking down the front barrels while you open the throttle. It should squirt gas.
Hope that helps,
Kerry
cristoDathird
28
May 30, 2019 08:47 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
sterling7
18
Sep 27, 2002 02:03 AM
