Easiest way to add torque?
Old Apr 20, 2009 | 03:26 AM
Slidin7's Avatar
Im in the process of rebuilding my 1990 Turbo II and I'm a lil worried about the acceleration any tips to bump it up
Old Apr 20, 2009 | 03:33 AM
wildacex187's Avatar
moar boost?!
Old Apr 20, 2009 | 03:36 AM
Slidin7's Avatar
thats what i'v heard, what about a chip/
Old Apr 20, 2009 | 04:24 AM
20Bforme's Avatar
three spinning triangles
https://www.rx7club.com/showpost.php...55&postcount=5
read through that... your answer on that "chip" is also in there.
Old Apr 20, 2009 | 05:09 AM
Lewk_FCRX7's Avatar
PWNIN
Sequential turbocharging or variable area turbine. But then expect to up the fuel consumption considerably.
Or just accept the fact that no rotors make decent torque down low lmao. Get a plonker if you're after that.
Old Apr 20, 2009 | 05:30 AM
sen2two's Avatar
Rx2 > FD
there isnt many ways to add toque to a rotary without basically doing a full build. but there are a few ways to make sure you keep the torque you have.
inertia aids and creates torque. so, keep the stock flywheel. also the heavier TII drivetrain aids in that. dont lighten the rotors.
or just be gay and add a huge torque producing paper weight V8...
Old Apr 20, 2009 | 06:26 AM
clokker's Avatar
Cake or Death?
Originally Posted by sen2two
there isnt many ways to add toque to a rotary without basically doing a full build. but there are a few ways to make sure you keep the torque you have....or just be gay and add a huge torque producing paper weight V8...
I'll bet you've never driven such a car.
T'aint nuttin "gay" or "paper weight"-ish about it.
Granted, it completely changes the nature/focus of the car but, depending on what you're looking for, this is not necessarily a bad thing.
Old Apr 20, 2009 | 06:58 AM
Matthys333's Avatar
Brap! Brap! Brap!
port it....my buddy that use to work for mazda helped build this rx7 that only had somethin like 185hp but like 300+ ft/lbs of torque don't quote me on the exact numbers but I couldn't believe it either....keeping that thing on all fours from a stop was nearly impossible...basically you can up the torque, but with anything that does with 7's, you gotta have $$$
Old Apr 20, 2009 | 09:40 AM
Dltreezan's Avatar
My Bick is Digger
^ Doubt it.
Old Apr 20, 2009 | 11:44 AM
farberio's Avatar
NASA-MW ST4
Originally Posted by Matthys333
port it....my buddy that use to work for mazda helped build this rx7 that only had somethin like 185hp but like 30+ ft/lbs of torque
fixed
Old Apr 20, 2009 | 11:52 AM
jjcobm's Avatar
Are you experienced?
you did say the easiest right?
http://kalecoauto.com/index.php?main...products_id=30
this is the first thing that came to my mind when I heard the words torque, 13b, and easiest.
Old Apr 20, 2009 | 12:41 PM
FattMarrell's Avatar
^ in combination with:
http://cgi.ebay.com/ebaymotors/New-E...Q5fAccessories
Old Apr 20, 2009 | 01:03 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
keep stock ports, use small-diameter intercooler piping, and run a hell of a lot of boost. your torque curve will be awesome
im not so sure on what was said about lighter flywheel/drivetrain reduces torque? can somebody explain that one? I can see how it will help the top end, but i cant see how it will hurt the low end
Old Apr 20, 2009 | 01:06 PM
Aaron Cake's Avatar
Engine, Not Motor
Every modification that adds HP adds toque. As HP is a calculation involving RPM and torque, you add torque to add HP (or add RPM).
A modest boost increase will help greatly. Get an FCD and turn the boost up to 8 PSI and you'll be a lot happier without having to spend a great deal of money on fuel mods. Or, you can get similar effect by opening up the exhaust and intake even if the boost remains stock (which is kind of hard to do because of the small wastegate).
Old Apr 20, 2009 | 01:09 PM
Frostycrowd's Avatar
echarge your whip
Old Apr 20, 2009 | 01:32 PM
RiCKoLA's Avatar
That KaleCoAuto site is great!! I just can't decide on what to buy first. LOL
Old Apr 20, 2009 | 02:33 PM
jjcobm's Avatar
^ They got the boost bar, thats something worth looking at and also the engine oil bypass kit : )
Old Apr 20, 2009 | 02:39 PM
mightymite's Avatar
y not just swap to a higher ratio rear end or trany ive heard of peaple using gears from a miata if i recall correctly
Old Apr 20, 2009 | 02:48 PM
Rx7TyreBurna's Avatar
Becoming pure track...
I am a big fan of.....
http://kalecoauto.com/index.php?main...products_id=28
But a little out of my price range. Saving up for it though. Should help me win a bunch more races.....
If not, I'll just go back and redo them.
Slidin7's Avatar
thx guys, ill have the car running in about a week i'll post pics of it in the next few days everyone has been telling me it's a rly rare model but the only person to explain to me why its rare said it had the bronze window tint, and something to do with the body, I'v looked every where to find out what he was talking about but havn't found anything
Old Apr 20, 2009 | 03:07 PM
Roen's Avatar
The Silent but Deadly Mod
Yea....you've been lied to.
Old Apr 20, 2009 | 03:14 PM
Slidin7's Avatar
y is that
Old Apr 20, 2009 | 03:46 PM
rotarygod's Avatar
Rotors still spinning
Where do you want to add torque? Low end torque? High end torque? You have low compression rotors and a restrictive untuned exhaust. A turbo is pretty restrictive compared to a header! That combined with little displacement leaves little low end torque. As a person who drives an n/a all the time, I'm not sure what you are worried about. My n/a is a torque monster compared to my Civic which is just a plain joke.
Old Apr 20, 2009 | 03:49 PM
20Bforme's Avatar
is it a 10AE (anniversary edition)?
Old Apr 20, 2009 | 05:06 PM
RotaryRocket88's Avatar
Top Down, Boost Up
On a serious note, more boost on the stock turbo will give you a nice broad torque band.
On a not so serious note, piston return springs can help too. http://kalecoauto.com/index.php?main...products_id=27.
"KaleCoAuto has produced the highest quality piston return spring to date! High temperance chromed metal resists temperatures up to 300'f. KaleCoAuto piston return springs FORCE the pistons back into the motor, no longer relying on gravity! This effectively increases your revs, horsepower, and peak torque! You must buy one return spring per piston. Rotary engines require install of pistons for full compatibility. One per piston. Please specify if you are using a boxer motor!"
