S4 Wastegate Porting Fun
Old Apr 13, 2009 | 01:47 AM
1SWEET7's Avatar
Now With 10th AE Fun!
I have been planning to port my miniscule wastegate for some time now. I am taking it to a local machine shop tomorrow and getting it ported to about 33-34mm. I would do it myself but I don't have air tools. I will post a before and after pic to show the results.
Old Apr 13, 2009 | 07:24 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
you can also shave down the backside of the flapper door, so that it opens further
Old Apr 13, 2009 | 08:19 AM
SirCygnus's Avatar
whats going on?
opening the door father does nothing. once its open, its open.
Old Apr 13, 2009 | 04:26 PM
1SWEET7's Avatar
Well thank you S & H Automachine in Fortuna, CA for doing an amazing job. Great guys. Here are my after ported pix. It is ported to 33mm.
Attached Thumbnails S4 Wastegate Porting Fun-ported-wastegate.jpg   S4 Wastegate Porting Fun-ported-wastegate-2.jpg   S4 Wastegate Porting Fun-ported-wastegate-3.jpg
Old Apr 13, 2009 | 06:33 PM
KhanArtisT's Avatar
Former FC enthusiast
^Holy **** thats nice!!!! How much did that cost if you don't mind me asking?
+1, hook up a hand bicycle/vacuum pump to your wastegate line after doing that mod and note how far the wastegate actually moves the flapper. I felt pretty dumb after I spent like 20 minutes sitting there porting the backplate with my dremel.
Old Apr 13, 2009 | 06:51 PM
rogrx7's Avatar
Turbovert done.
cost dude
Old Apr 13, 2009 | 08:29 PM
1SWEET7's Avatar
They charged $80/hour and it took a little over 2hrs but he only charged me for 2 and they welded the flapper for me. I gave it to them at 9am today and had it back at 2pm.
I finished putting it all back together and wow! Way faster boost response. I am going to go out tomorrow and re set my boost controller. I am very happy with the results though, top notch quality.
Old Apr 13, 2009 | 08:37 PM
Nismo Convert86's Avatar
400WHP or bust
Yes it does, I proved this on the Dyno. With my S5 turbo's ported WG I could still creep to 10psi, with the ported WG, and the backing plate shaved down I couldn't boost anymore than 7.2ish... Hooked up the boost controller, and I can boost 10psi again. BDC was there, and saw this.
Old Apr 13, 2009 | 08:38 PM
400WHP or bust
So it worked for you too?
Old Apr 13, 2009 | 09:47 PM
Davidov's Avatar
No, the opposite. Your result was due to the boost controller.
Old Apr 13, 2009 | 10:34 PM
KhanArtisT's Avatar
Nah it didn't work for me. I'm using an S4 actuator on an S5 turbo with a bent rod though so maybe thats only true of the S4 actuators. I applied pressure to mine (already confirmed the backplate was ported right and the additional movement of the flapper with no wastegate) and it didn't go further than before I did the porting.
Old Apr 13, 2009 | 10:50 PM
1SWEET7's Avatar
Well there seems to be zero boost creep now. Before I would creep up to 9lbs or so. Feels so good!
Old Apr 14, 2009 | 06:56 AM
400WHP or bust
No, the Boost Controller was never hooked up. Once we used the boost controller it allowed about 2.5-3psi of creep. Before the boost was rock solid at 7.2psi, prior to that with the stock plate I could boost 10-13psi without issue, and that was with a massive WG.
I know this works on the S5 with a ported Wastegate, the S4, I can't say, but from the sounds of it it doesn't work.
Old Apr 14, 2009 | 10:01 AM
gxl90rx7's Avatar
I had an extra S4 hotside laying around, and last night i checked it with 10psi. the wg arm moves about 1/2 inch, which makes the door just touch the back of the housing. grinding down the back of the door may or may not help, but it definately cant hurt
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Clacor
Sep 11, 2015 08:36 PM
