gt4o a/r .85
Old Apr 9, 2009 | 10:17 PM
87turboIIpat's Avatar
boostedfc
gt4o a/r .85
hey guys just wondering how a gt40 with an a/r .85 would spool on my fc.
i have a 87 turboII with stock ports. just purchased 1680cc secondary injectors and plan on using the stock 550 primarys. I already have the haltech e8 ems and apexi boost controller. planning to boost 14 or 15 psi.
Old Apr 10, 2009 | 01:42 AM
slpin's Avatar
7th Heaven
it would spool it and give you about 2-3k of usable power
Old Apr 11, 2009 | 02:27 PM
boostedfc
even with an a/r of .85 you dont think it will spool very fast. it will also be a BB turbo.
Old Apr 13, 2009 | 11:54 PM
boostedfc
anyone else have any more information. i was thinking of going with a gt35r but i plan on porting the engine and raising the boost in the future. want to buy the right turbo first time around
Old Apr 14, 2009 | 12:15 AM
sk8world's Avatar
Chasing numbers
I ran one on a stock port REW and it was fine.
Old Apr 25, 2009 | 06:59 PM
boostedfc
sorry for bringing this thread back from the grave but i was hoping for some more information. if anyone else has ran the gt4088r i would like to know how it turned out.
thanks pat
Old Apr 27, 2009 | 03:21 AM
tony94s4's Avatar
Corn Fed FD
I run gt4094r with .85,
have around 500whp @ 7600rpm and does not drop will try to rev higher soon,
20psi @ 4k. rpm
Old Apr 28, 2009 | 01:44 AM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
3 general problems with smaller housings is they restrict the exhaust more making less peak power, they contain the heat more which raises EGT's, and they tend to feel a bit flatter in the top end especially at higher boost levels. For more reliable power I'm starting to lean more towards the larger exhaust housings with a slightly smaller compressor side if spool is an issue. A .96 is considered small for the Aussie guys. But I imagine there is a lot of factors that can change depending on wheel designs and such. On my old turbo I ran a .84, on my new one its .96 and it spools slower but the whole turbo is much bigger so it's hard to say what had a bigger factor. I don't think I would have noticed much difference in spool just from the housing change.
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
