:) LISTEN, i need wide ass 16's for my FD.
Old Mar 30, 2009 | 10:28 PM
vr6t3t4's Avatar
:) LISTEN, i need wide *** 16's for my FD.
i cant find **** that will look cool and fit right with some poke.
im getting rid of my bbs lm's and i want some 16x10's or something that look sweet but i cant find anything.
i just wanna have some poke and slam my fd on some wide *** 16's cause i know it will look tight.
anybody know of anything. steel, alloy, anything.
post picks.
also if anybody has a pick of an FD with cool 16's on it post it up.
thanks guys!
Old Mar 30, 2009 | 10:38 PM
jdmsuper7's Avatar
Looks ahead!
16" tires are getting very uncommon, especially in wide sizes. You will seriously be much better off with 17s.
Old Mar 30, 2009 | 10:41 PM
Mahjik's Avatar
Mr. Links
Unless you go with a custom wheel, it's very doubtful that you'll find anything in a 9-10" width at 16" which will work on the FD. As mentioned, tires in those sizes are generally race tires as well.
Old Mar 30, 2009 | 10:47 PM
JStrib's Avatar
Recovering Rotary Guy
That would be mad tyte yo.
Old Mar 30, 2009 | 11:18 PM
vr6t3t4's Avatar
im gunna stretch tires so im all good on that
i just cant find ze rims....
Old Mar 31, 2009 | 12:20 AM
vr6t3t4's Avatar
would a 17x11 offset 29 fit on the rear of an fd?
Old Mar 31, 2009 | 01:35 AM
Miata_mx5's Avatar
Wangan Nasty
Depending on tire size, alignment, suspension upgrades and fender modifications: Yes.
If you want wide *** 16s: Kodiak Racing makes forged 16 inch wheels up to 14 inches wide i believe.
http://www.kodiakracingwheels.com/prices.html
CCW Also makes their Classics and Classic/4s in up to 16 inches WIDE on a 16, 17 or 18 inch diameter wheel (as per what i can tell from their website).
http://www.ccwheel.com/files/wheelpr...php?id=Classic
You are definitely looking at 3 piece wheels too to pull something like this off: I know SSR Professors come up to 10.0 J wide for 16s (SP1-R) and up to 12.5 J to 13 inch J wide for certain 17s (SP1 or MS1-R)
Your options are more limited with mono-block wheels but you can get somewhat close.
Either way price wise the setup will cost around 3000 dollars up with tires.
Old Mar 31, 2009 | 08:46 AM
vr6t3t4's Avatar
thank you, so if i had a moderate pull on my rear fenders i could stick a 17x11 et29 under there if i made my camber all crazy.
Old Mar 31, 2009 | 08:59 AM
ptrhahn's Avatar
There are no good white basketball players, my friend.
Old Mar 31, 2009 | 10:09 AM
gracer7-rx7's Avatar
needs more track time
I love when you use that line. I get a good laugh out of it.
Old Mar 31, 2009 | 11:04 AM
ptrhahn's Avatar
I guess I need new material :-)
Seriously, wide tires for small diameter rims are getting tough to find. My friend's father in law had this problem with his vintage Pantera.. damned thing had 345's on the back on 15" Campagnolo rims.
Old Mar 31, 2009 | 11:50 AM
Miata_mx5's Avatar
Wangan Nasty
There are a few things you need to make sure first:
Brake clearance: If you want to run a big brake kit, you need to run the appropriate disk (different per wheel manufacturer), to clear the brakes.
Suspension: You need to make sure you coilovers/suspension can support the ride height that you want while still keeping drivability.
Suspension Modifications: If you will go extremely low, i would get roll center adjusters, and other suspension parts so that you can still retain the car's handling.
Tires: If you want to be tire flush and run a meatier tire, you should probably roll, pull the fenders and setup the alignment accordingly. If you want to stretch the tire and do "wheel flush/VIP style", then you need do the same thing, but the alignment will most likely be different.
Best way is to try to measure the car up using a drop string/hub measurements or borrow some spacers and stack them on your current wheels till you have the wheel where you want it. Then you can do some offset and width calculations.
That's on my car with 17 x 9 + 20 with spacers all the way around (while i order custom wheels later). I have a 245/40/17 tire, which is more than enough to support stock 280-300 horsepower. Coilovers are GAB-Sports on all the way low setting with removed helper springs. I plan on getting custom Penske coilovers later. My camber is not crazy (in fact, i cannot even adjust it right now because i need Camber arms to do so).
Wheel and tire fitment/car's stance and suspension setup both have to work hand in hand and be done together otherwise the car won't drive right, or look good.
Old Mar 31, 2009 | 03:49 PM
carman594's Avatar
Wide tires look sweet
Old Apr 1, 2009 | 10:37 AM
muibubbles's Avatar
Bubblicious DEF.
omg those kodiak rims are SEXXXXXXXXXXXXXXXXXXXXX
ls1swap
Jun 3, 2024 03:25 PM
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
