86 rx7 non turbo tranny noise
Old Mar 29, 2009 | 09:25 AM
dodos6999's Avatar
MI 86 rx7 non turbo tranny noise
does anyone know what would cause noise coming from the tranny when clutch is out, no noise when clutch is in, and the release and pilot bearings were changed out.
Old Mar 29, 2009 | 02:04 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Possible the Pilot bearing got damaged on the install, I have messed more then one up in my life time
Old Mar 29, 2009 | 03:03 PM
trochoid's Avatar
Old Fart Young at Heart
Neither the pilot bearing nor the the release bearing make noise when the clutch is out. Only when the clutch pedal is pushed in do they rotate at different speeds in relation to the other tranny parts. I'd start with checking the fluid level and the u-joints.
Old Mar 29, 2009 | 08:04 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Noise when the clutch is released will typically be the front main bearing in the transmission. I had to replace the one in my old NA transmission after it started making a droning noise while sitting in neutral w/ the clutch out.
Old Mar 29, 2009 | 08:26 PM
dodos6999's Avatar
thanks a lot guy's
Old Mar 29, 2009 | 09:28 PM
farberio's Avatar
NASA-MW ST4
You sure? My release bearing is pretty loud with my clutch out and before it warms up.
Of course now I have solid mounts everywhere. That may also be the cause...
Old Mar 30, 2009 | 10:36 AM
philiptompkins's Avatar
your probably F'ed. make sure the tranny isn't dry
autoxer
21
May 22, 2019 04:07 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
NJ-JDM
43
Aug 23, 2015 11:02 PM
JBatista1994
Aug 14, 2015 11:23 AM
