Noob! Looking for replacement hoses
Old Mar 24, 2009 | 12:15 PM
BrownBoy's Avatar
To Efini And Beyond
Hey all,
I finally picked up an RX-7 this past weekend and I remember hearing that I should replace the vaccum hoses to avoid any cracking or leaks. There's already 88,000km on the car so I figure I should try to do this pretty soon.
Where is the best place to buy these from?
Thanks in advance!
Old Mar 24, 2009 | 01:36 PM
Aaron Cake's Avatar
Engine, Not Motor
The easiest would be the local Mazda dealer. However getting all those hoses would be a major pain. Instead, pick up an assortment of silicon vacuum hose at the local auto parts store and just replace one piece at a time, cutting the silicon to fit as you go.
Old Mar 24, 2009 | 10:53 PM
trochoid's Avatar
Old Fart Young at Heart
As a side note to add to Aaron's reply, be very careful when removing the old hoses from the plastic barbs. They tend to snap off. Use a utility or Xacto knife to split the hose, then spread the cut and carefully twist and pull the hose.
Old Mar 25, 2009 | 10:44 AM
BrownBoy's Avatar
To Efini And Beyond
Thanks guys, I'll look into that this weekend.
Are all of the hoses the same diameter and would regular hose clamps be sufficient to hold them in place?
whinin
Mar 30, 2019 07:53 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Apoc3D
Sep 5, 2015 10:24 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
