sitting ENGINE...
Old Mar 21, 2009 | 02:56 PM
KING7's Avatar
GETTING THE FD ROLLING
Question sitting ENGINE...
I have a ENGINE that has been sitting out of a car for about a year an a half. It is a single turbo conversion 3mm ported . I just got a roller to put it in. The ENGINE was in a garage on a crate. It has sitting there with no fluids and no oil in it. When I turn it there still a puff. So I am hoping the compression is good
1. What should i do in order to have it up an running.
2. While it is out is there any way I can check the seals?
3. Are should i go an change the seals out now while the motor is out of the car?
4. Should i change the vacuum hoses out as well?
Open to any help or opinions
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
LongDuck
Oct 7, 2015 08:12 PM
dexter snoek
Sep 29, 2015 09:18 AM
