Mazdatrix Rubber Antenna
Old Feb 27, 2009 | 06:27 PM
REDFC3S86's Avatar
I just bought the mazdatrix rubber antenna and installed it. The antenna only connects to the cable that runs to the the radio. There aren't any other wires or connectors. Right now i have my stock power antenna assembly tucked where the stock scissors jack goes (its hidden under the carpet)....There's a connector that goes from the antenna assembly to the speakers.....If i fully remove the stock assembly, I get no sound (from either the cd output or tuner output)...Is there a way to rewire the speakers do i can ditch the stock antenna assembly altgother? (Rubber antenna is connected to Radio jack, stock antenna is tucked away but still connected to speakers).....Thanx..... And yes i searched.
Old Feb 27, 2009 | 07:16 PM
Icemark's Avatar
The antenna and speakers are unrelated. They are not tied together.
Old Feb 27, 2009 | 07:25 PM
REDFC3S86's Avatar
Hmmmm.....When i unplugged the one connector from the stock antenna, i got no sound, but when its plugged in, i get sound....figured it was the speakers. Thanx for the input Icemark
Old Feb 27, 2009 | 10:03 PM
eage8's Avatar
1308ccs of awesome
when you're playing the radio? sounds like you're still hooked up to the stock antenna....
the stock antenna has 2 wires because one is the power to go up and down.
Old Feb 27, 2009 | 10:10 PM
NCross's Avatar
I have a rotary addiction
Just plug it in and leave it alone. If you don't care about AM FM radio and only care about looks then remove the antenna and put a grommet in the antenna hole on the deck lid.
If I'm not mistaken...
The power antenna triggers a relay to the head unit as a "turn on" signal right?
Old Feb 27, 2009 | 10:56 PM
13bturbofc's Avatar
mmm doritos
if i was you i would call mazdatrix and ask them. they're customer service is awesome..just out of curiosity, how long is this rubber antenna replacement? I'm looking to replace the ugly stock one..
Old Feb 28, 2009 | 02:42 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Grounding that you get from the stock antenna missing with the rubber antenna?
Old Feb 28, 2009 | 04:31 AM
RX7Tuner.'s Avatar
I really Schruted it
The stock antenna is grounded via one of the mounting screws.
Old Feb 28, 2009 | 12:23 PM
eage8's Avatar
1308ccs of awesome
it's decently long, probably around 2 feet.
Old Feb 28, 2009 | 04:05 PM
REDFC3S86's Avatar
Its not that long maybe a foot at best. So why do i not have sound if i remove all connections from the stock antenna? Any ideas?
Old Feb 28, 2009 | 04:35 PM
Juan's Avatar
Im a tall midget.
Does your head unit completely turn off when you unplug the stock antenna? Do you have a stock or aftermarket head unit?
Old Feb 28, 2009 | 07:13 PM
misterstyx69's Avatar
Retired Moderator, RIP
I bought a Rubber antenna from a high end Auto Specialty Shop.
The name of the Shop is:WALMART!.I paid like 12 buckc Canadian.
The antenna works like a Charm.Good reception.
I ditched the old retractable antenna as it not longer worked,and the Kids around here like to Break off **** like that.
Old Feb 28, 2009 | 08:35 PM
13bturbofc's Avatar
mmm doritos
the one at mazdatrix is only 20 bucks and im sure it probably looks and fits a little better. but if your on a budget there is nothing wrong with what you got..
Old Feb 28, 2009 | 08:38 PM
Icemark's Avatar
The mazdatrix one is just a generic rubber antenna, and not any better than any other short antenna. Anytime an antenna is less than 31.5 inch's, it will have reduced reception when compared to a standard height antenna.
Old Feb 28, 2009 | 09:15 PM
13bturbofc's Avatar
mmm doritos
yeah but there is still different quality generic antennas.. and there are many different designs out there. i don't imagine mazdatrix just went out and bought a random antenna they found at walmart. I'm sure they did some research to find one of higher quality and fitment..
Old Feb 28, 2009 | 09:40 PM
Icemark's Avatar
On these antennas (the universal rubber ducky) they are all made by the same company (Harada), and then sold under a dozen different names and locations.
Old Feb 28, 2009 | 09:52 PM
13bturbofc's Avatar
mmm doritos
really?? damn never knew that..ill have to check that out.
Old Mar 1, 2009 | 08:59 AM
REDFC3S86's Avatar
the head unit always turns on if i press the power button (if the engine is running or if the key is in the ON position)..regardless of whats connected in the back with the antennas......its a pioneer head unit btw. no sound if unplug the stock antenna from the harness though
Coochas
44
Nov 5, 2019 11:08 PM
musker
Oct 1, 2015 05:58 PM
Jetlag
Sep 29, 2015 06:52 AM
