Gas in oil, does that mean it's shot
Old May 23, 2002 | 04:42 PM
Was gas in oil now: Is my motor gone?
Just changed my oil, it reeks of gas, does this mean apex seals are shot?
help
steve
Old May 23, 2002 | 05:31 PM
Silkworm's Avatar
Has been.. hangin' around
No, it means that you probably have leaking injectors. Not a huge problem, but if you want a tip top condition car, you should go after that.
PaulC
Old May 23, 2002 | 05:32 PM
peejay's Avatar
Old [Sch|F]ool
It's a rotary, that's kinda normal...
Old May 23, 2002 | 05:38 PM
Aaron Cake's Avatar
Engine, Not Motor
No. If anything, it would mean your side seals are shot.
Honestly, you probably need to get your injectors cleaned. And peejay is right, most rotaries tend to pollute the oil with gas.
Old May 23, 2002 | 05:42 PM
do i have to pull the injectors to have them cleaned?
also, i have a fuel cut off that i use every time i shut down the car, shouldn't that mitigate the problem?
Old May 23, 2002 | 05:47 PM
Bambam7's Avatar
I came, I saw, I boosted.
Ya got me wondering.... how do you come to the conclusion that the injectors are leaking??
If they are leaking to the point to where they are filling the chambers with gasoine, and leaking past the side seals into the "crankcase".... you have an engine that would never start, and have much larger problems.....
My oil smells like gas too- which isn't a good thing- it really degrades the oil... that why I change it every 3 months!
I think just about all rotaries have this phenomenon.
Old May 23, 2002 | 05:54 PM
I havent come to any conclusions. let me tell you my situation. I have a car 103k previous owner claims motor is out of a wreck with 40k on 15k ago. i bought the car with 91k in december of 01. About two months ago, i started having flooding problems, so i changed plugs and installed a fuel cut switch. now, when i start the car, it takes about 30 seconds to even out, sounds like its not running on both rotors for that first 30 sec.
after that, runs like a bear, no problems. Accellerates as well as you can expect a basically stock n/a to. When i shut it down, i always smell gas, i have replaced the fuel filter, hoses to and from filter, and the return hose. havent changed lines to the fuel rails, because i don't know where they originate. There is no sign of leaking gas oil or coolent under the car at any time. I can not find any fresh gas on the motor either. I changed my oil again (after about 2k) and it just simply reeks of gas, not just a bit, but a lot, but all in all, oil is reletively clean. any ideas?
Old May 24, 2002 | 01:39 AM
bump
Old May 24, 2002 | 07:56 AM
Samps's Avatar
The system that removes the fumes from your oil system may be not functioning properly. There is a black round valve (forget the name) but it is like $50 (ask me how I know). I believe there are other components that also work on removing the fumes. You might want to look into it.
Microtech
30
Apr 23, 2016 06:37 PM
smikels
Aug 18, 2015 01:26 PM
