full boost stumble on t2
Old Feb 23, 2009 | 02:31 PM
maz87t2's Avatar
i have a 87 se with a turbo 2 engine and drive train. the car was running perfect with the top mount intercooler. never missed a beat in boost and out of boost. the engine is a rotary ressurection rebuild 3mm apex seals and large street port. it has the stock turbo at ab 9 to 10 psi. stock injectors. has a aeromotive fuel pressure regulator. set at roughly 35 psi with vacuum on. i turned the pressure up some on the regulator so i would get alittle more fuel. with switching to my fmic will i need to tune the fuel system? ran perfect with top mount at same boost level. now front mount has full boost hesitation.like if i hold it hafe throttle and its at like 7psi its ok all the way to ab 7000 when i shift. just at full throttle it cuts out and has back firing. do i just need to ditch the front mount? or tune the fuel and timing. since i am assuming the air is alot colder now with the front mount. i felt the tubes and the hot side going into the intercooler was warm and coming out was cold like it was supposed to do. didnt know if that was my problem. maybe a fuel cut in the computer?
Old Feb 23, 2009 | 03:07 PM
t24todd's Avatar
RE_p Rotors
sounds like your getting to much fuel, what size piping with the fmic?
Old Feb 23, 2009 | 03:18 PM
maz87t2's Avatar
well i didnt change the fuel pressure at all from the swap. hot side is 2 1/2 i think and cold side is 3 inch all the way to intake.
Old Feb 23, 2009 | 03:51 PM
maz87t2's Avatar
oh and it has a walbroh 255 in it.
Old Feb 23, 2009 | 03:56 PM
freemanrx7's Avatar
^Hold On
9-10lbs of boost on stock injectors is not good. If you do tune get an rtek 2.1 with some bigger injectors. Maybe set the boost controller to 7 psi and see what it does at full throttle.
Old Feb 23, 2009 | 04:09 PM
eage8's Avatar
1308ccs of awesome
yeah, there is no way he's getting too much fuel if he has stock injectors. upgrade your injectors. and get an rtek if you don't want a standalone.
http://www.pocketlogger.com/index.php?pid=rtek7
Old Feb 23, 2009 | 08:41 PM
maz87t2's Avatar
would a boost leak cause this? i put the stock top mount back on it today and back to no problems. im looking on there and see no 2.1. could u direct me to this. i was gonna upgrade anyways
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
R7rexy
19
Sep 2, 2015 10:24 AM
CaptainKRM
15
Aug 29, 2015 01:33 PM
smikels
Aug 18, 2015 01:26 PM
Turblown
Aug 14, 2015 04:48 PM
