boost creep!!
Old Feb 18, 2009 | 08:21 PM
fcnoevil's Avatar
boost creep!!
alright so info i have an s4 motor stock port stock ecu stock s4 turbo with a full 3in turbo back exhaust and a front mount... car has an electronic boost controller on it 1 will the boost controller prevent boost creep or is there more i have to do? and 2 what is a safe psi (of boost) to run on this engine setup? i wanna make ok power for a reletivly stock car but dont really wanna sacrifice reliability cause this motor is brand new and im not made of money... I searched around and kinda got an answer but im not satisfied... please help
Old Feb 18, 2009 | 08:48 PM
eff_three_see_es's Avatar
lycanthrope
1:port your wastegate
2:get fcd
3:set boost at 9psi
Old Feb 19, 2009 | 12:23 AM
boostinfc3s's Avatar
might aswell get a s5 lim and a s5 turbo. THEN port the **** out the WG and do what you gotta do
Old Feb 19, 2009 | 12:48 AM
freemanrx7's Avatar
^Hold On
Used s5 turbo with a huge ported wastegate will solve your problem. I run stock 5.5 PSI w/ the smaller 2.5" full RB exhaust.
You can combine your good s4 turbo with a blown s5 turbo. All you need are the manifold and hotside.
Old Feb 21, 2009 | 10:46 AM
fcnoevil's Avatar
dont wanna sound retarded but why would i need an s5 lower intake mani?
Old Feb 21, 2009 | 11:33 AM
freemanrx7's Avatar
^Hold On
You don't NEED it. The s4 works fine!
Old Feb 21, 2009 | 03:41 PM
rotaryracer1's Avatar
hey man you should really take your turbo off and port the wastegate hole and weld a new flapper door on to help control any kind of boost spike. a good psi is probly stock which i think is like 6-8psi. i hear the stock turbos arent that good at higher boost levels so you will wanna stick with that probly. i just got done with porting my wastegate hole and i love that i can finally just ****** rip it up and down the canyon with no fear of over boosting. there is a website fc3spro.com that has a step by step. check it out.
Old Feb 21, 2009 | 08:26 PM
arghx's Avatar
rotorhead
even with a mildly ported s5 wastegate my car still creeped with a straight through 2.5" exhaust (big street port).
Old Feb 22, 2009 | 08:33 AM
Furb's Avatar
Rotary and Engineering
mildly is your problem... you need to port the **** out of that wastegate!
there is A LOT of material that can be removed, and just opening up the holes under the flapper isnt enough!
Old Feb 22, 2009 | 03:04 PM
freemanrx7's Avatar
^Hold On
I'm have stock ports and no boost creep. I know there is more material to take out that lets the air run smoothly out the wastegate. If you look inside the wastegate you can see 90deg bends. Just smoothing out those corners will help some.
BlueTII ported my wastegate. Maybe he will chime in and post a pic or two. His stock turbo is awesome.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
